Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Avalanche
Old 09-23-2009, 03:14 PM
mandtra mandtra is offline
O2 oxygen sensor problems ?
I recently replaced the drivers side CAT and both upstream O2 sensors . The cat was cracked and rattling. The drivers side sensor 1 had a bad heater circuit (Po135), and the O2 sensor 1 on the passengers side would only read .07v constant. where the other three were reading .1 - .7volts.
I replaced both upstream O2 sensors with NGK sensors, and ran another scan today . bank 1 was fine .1 - .7 v (both) , but bank 2 sensor (one) upside was staying at .070 v and sensor 2 downside was .1 - .7 so I assume I have more problems. since the brand new sensor in bank2 sensor one is still reading .07 constant.
What do you think?
Old 09-24-2009, 12:51 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: O2 sensor problems ?
I'd test the wires for that sensor for continuity back to the ECM...my bet is that the sensing wire is grounded somehow.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-25-2009, 09:56 AM
is it possible a bad cat on that side could cause that low voltage reading?
Old 09-25-2009, 02:52 PM
Here's an update. I tested the o2 sensor wires from sensor to the PCM. Everything checked out fine. I also warmed the engine up and sprayed starting fluid all around looking for a vacuum leak. no luck there either
Tags
oxygen , po135 , s12 , sensor
