Old 05-27-2002, 04:40 PM
felnblu felnblu is offline
throttle position sensor problem
i just put a zc in my 4th gen and the ecu still throws out the tps code. we put a new one on and switched the outer wires. has anyone else had this prob?
Old 06-06-2002, 01:16 PM
SFF900 SFF900 is offline
Did you reset the ecu? Also did you check the continuity of the wires all the way from the sensor to the ecu? Test in the plug for the sensor and the plug for the ecu. If you replaced the sensor and all the wires are good, and you reset your ecu the only thing left is the computer.
Old 06-06-2002, 04:51 PM
yeah i havnt went that far into checking but i think i am going to get the integra computer and see what that does.
