Go Back   Automotive Forums Car Chat > Plymouth > Acclaim
Old 08-11-2003, 05:26 PM
mbeach's Avatar
mbeach mbeach is offline
Unhappy Have to jump the starter
I have a '93 acclaim, 4cyl (not flex fuel, whatever that is), auto trans.
Turn the key and the the solenoid doesn't even click, but the starter does engage with a jumper wire run directly from the battery to the small post on the solenoid. According to the Haynes manual for this car that means the problem must be the starter switch, neutral start switch, wiring or fusible link. All seem to check out o.k. By that I mean the starter switch was replaced, with a new one, tried two different junk yard neutral start switches and visually checked the fusible link. What did Haynes leave out?
One should never attempt to ascertain the total number of units in a collection of gestational poultry until said collection has fully incubated.
Old 08-12-2003, 01:15 PM
mbeach's Avatar
Also, when I put in reverse (and/or turn on the a/c fan) instead of reverse lights, the e-brake indicator lights on the dash.
Old 08-13-2003, 09:29 PM
pcv pcv is offline
Try tapping on the ASD relay that is located on the left front fender, next to the battery. Wire from there goes to the starter. Try tapping it or replace it with a good know part.
NOTHING LIKE AN OLD CAR.
Anyone ever have issues w/ the starter toggle switch? Question. Cobra4B GTRA / GTWS / GTS 6 08-31-2009 10:06 PM
Could it have jump time? memedos76 Accord/TSX/Accord Hybrid 2 01-02-2009 12:25 PM
96 jimmy jumping against starter thinktinker Jimmy 0 12-24-2006 01:03 PM
Hyundai Sonata may have jumped timing...or is flooded?? I need help! Ferngee Sonata 3 12-22-2004 06:22 AM
96 jimmy jumping against starter soyo102 Jimmy 1 07-18-2004 11:18 PM
