Old 01-01-2009, 08:29 AM
memedos76 memedos76 is offline
Could it have jump time?
90 honda accord. Filled car up with gas and put in one quart of oil. then drove it from Tulsa Ok to Oklahoma city about 90 miles and it just died. When i looked at dip stick there was no oil and no water in radiator. Told it possible it jumed time its it possible.
Old 01-01-2009, 05:19 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Could it have jump time?
It never overheated?
Can the starter still crank it?
I assume you refilled the missing fluids?
Did you pull the plugs out and see if fouled with oil or coolant?
If it turns over, does it sound normal or have an odd cadence as it turns?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 01-02-2009, 12:25 PM
mpumas mpumas is offline
Probably not, but other things may have happened. Things to check: Is camshaft still turning when you turn the starter? Are you getting spark? If the previous are answered OK, then look to fuel.
