Old 08-11-2003, 12:13 PM
BlueCivic83's Avatar
BlueCivic83 BlueCivic83 is offline
Send a message via AIM to BlueCivic83 Send a message via Yahoo to BlueCivic83
overheating on short distances
ok i've been told that it might be my water pump or thermostat...
i know my fans work because their always on.
for the thermostat i was told it might be stuck clode and is not letting much watter go trough it . Were is it located a pic would be hlepfull and how do i take it out to chek it ? and also is that a dificult job ?
Old 08-11-2003, 12:29 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
it isnt a difficult job to replace the thermostat, I had to do it on my old MGB.
I got absolutley no idea where its located on the civic though.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 08-11-2003, 01:02 PM
found what i was looking for with a simpler search thanks any ways
Just follow the lower radiator hose to where it connects to the engine. Take off the 2 bolts on that housing and inside it is the thermostat. Just pull the old one out and pop the new one in. Make sure to get a new gasket when you do this. You don't need to drain the radiator but stick a pan or something to catch all the crap that leaks out. Then just run the car and fill back up the radiator.
Old 08-11-2003, 04:20 PM
in the same psot someone said that you could just remove the thermostat and the only prob would be heating up the engine in the morning ....
so if i wanted to try it would that be the only problem ?
Old 08-11-2003, 04:55 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Don't just remove the thermostat, it has a job to play and is part of the system to regulate the temperature. You need to remember that optimum A/F is delivered by the ECU within a specific temp range. It's also bad news in the winter.
Check the radiator and have it flushed or re-cored - it's prolly clogged. Before that, buy a new thermostat and install it although remember that they usually jam partially open, not fully closed, so this might only be a contributing factor. You might also want to replace the radiator cap - if it's not pressurising the system then that could be the problem. Have the block professionally flushed and you might want to think about replacing the water pump - maybe.
Only other thing is that if these areas are stuffed, then it's a good idea to replace the radiator and heater hoses, not to mention all the smaller ancillery ones as they are prolly on their way out. Finally, always run coolant - it protects the radiator etc and flush it every 12 months with a hose and then renew the coolant.
Just some ideas
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 08-11-2003, 11:24 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
I dont know if anybody knows this (they must) but when you refill your system you have to purge the air out of the top. I had the problem with mine over heating a little bit. I just ran the motor and opened the fitting on the tube on top of the block. It stopped the over heating.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 08-11-2003, 11:44 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
To bleed the air out of the coolant just take off the radiator cap and let the car run, all the bubbles will come out.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-11-2003, 11:50 PM
Cjz89civic's Avatar
AF Premium User
Nope tried that did not work. This is what Honda told me to do at least the sevice tech did. And it worked
Old 08-12-2003, 10:18 AM
my radiator is in bad shape but i cant get a new one ttill the end of the week
i had put a radiator stop leak and was wondering if i put the radiator flush wont it open up all the wholes that the stop leak had closed. porbaly the stop leak is the cause of my problems...
Old 08-12-2003, 12:07 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Blucivic83 says the car overheats on short distances.
Sounds like the fans aren't coming on. When you're driving 45mph and higher, the air rushing through the radiator is sufficient to cool things down. At slower speeds, or stuck in traffic, you need the fans.
Simply taking the thermostat out won't solve the problem. Some cars need the thermostat's restriction to slow down the water so it has time to cool down in the radiator. Taking out the thermostat on those cars CAUSES overheating.
Fix it soon, or you'll have to replace a head gasket and get your head milled.
Flunky
PS-Bleeding the coolant from the 12mm nipple only takes 5 seconds.
Old 08-13-2003, 04:30 PM
oppenden it up and my thermostat was already removed ...
i'm thinking it's my radiator thats cloughed...
i want to use one of these radiator flushes... will it open up the small whole that the stop leak i added a few weeks ago had sealed ?
Old 08-13-2003, 04:58 PM
Setanta's Avatar
Most likely - in fact the stop leak actually clogs your radiator more Stop and think about it and you'll see why. It's a cheap fix and not a good one.
Get a re-core if you think it's clogged and definitely get the block flushed at the same time. Put a new thermostat in as well as (maybe) a new water pump and your set to go.
Also - can't hurt to get your timing checked - just in case it's too far advanced.
'99 PY DC2R
'85 BBS BMW E30
A smell like ketcup, after driving car for short distance bgarrett24 TrailBlazer | Trailblazer EXT 1 09-09-2007 05:03 AM
Leaking tranny (AT) OK to drive short distance? Rickchevy56 Chevrolet Classics 1 08-06-2007 05:57 AM
BMW 325i turbo. Short distance drag BTT Car Videos 0 07-28-2006 05:57 PM
keyless entry short distance austintxusa Blazer 3 01-27-2003 02:24 AM
