Old 08-10-2003, 11:29 AM
nuzzi nuzzi is offline
vr4 thoughts
i have a vr4 and i was wondering how people set up there turbos using the stock front one and an upgrade in the back and what is a good match if this is true, and also if this is possible. another thing i wanted to know if the turbos work together or one is a starter and the other for top end
Old 08-10-2003, 09:13 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
The turbos are sequential which keeps the spooling time down. You can just upgrade the rear one, but you'll increase the lag time for the smaller one to drive it. Replace both if thats what you'd like to do.
Before you do that though, have you done the BPU like a boost controler, open air filter and (if you can get away with it) open exhaust (gutted cats...)?
Resistance Is Futile (If < 1ohm)
Old 08-11-2003, 04:40 PM
vr4 thoughts
what turbo spools up first and what would a good second turbo be to get. i have already did my exhaust intake fuel but still deciding what to do about turbos. have knowledge about cars but a little lost about this problem because of so much hearsay
Old 08-12-2003, 07:14 PM
ikOnone ikOnone is offline
unlike that supra which i believe does have sequential turbos, no 3000 GT ever came with sequential turbos. the VR-4's all came stock with TD04 9b turbos with the exception of a few in europe that came with TD04 13G turbos. the 9b's spool very quickly because they are small (generally around 2500rpm if i remember correctly). anything is possible so you could make a sequential setup but any gains are far smaller than all of the effort that you are going to put into making it happen.
a very small number of people have run different turbos on the front and back and some have had good results. if you do decide to go this way, make sure you REALLY know what you are doing beforehand. one person was running a 13G and a 9b and ran some good times at the track, forgot who. the problem with this is that you can get back pressure in the side with the smaller turbo and you can mess a lot of stuff up. you would not want to run turbos that are very different (260 cfm turbo and a 400 cfm turbo for example) you can do a search on www.3si.org and you will find plenty of information on this.
the main concern that you will have running more boost or bigger turbos is the fuel system, not intake or exhaust. intake/exhaust will free up a lot of power and you should get a good boost guage (stock one is garbage) and a boost controller to make sure you can control your boost but the fuel is the main concern. if you do not have the fuel to back up the boost, say hello to detonation and good bye to your engine. you will want to upgrade your pump and possibly get bigger injectors or a fuel controller if you are going for really high boost. i would suggest you start with gutting all of your cats, getting a k&n nockoff air filter (just as good) and getting an $18 boost controller and a $15 boost guage. this can all be done for less than $100 and should put you at around 400hp at the crank. oh, by the way that is with boost set at 14.5 psi, the limit more or less of the stock fuel and turbo setup. that will hold you off until you know what you want to do (read up, you will thank yourself later )
common upgrades for a VR-4 turbo wise are 13G's 15G's 17G's DR500's DR650's GT347's GT357's 368-SX's and a variety of really pricy bigger setups and some new TD05 setups that are just now being released
for more information on the 3/S platform i suggest that you visit www.3si.org or www.stealth316.com there is a lot of good info on those sites!
hope this helps,
chris
Old 08-12-2003, 07:54 PM
chris i want to thank you for your time and ideas. i appreciate that you took the time to answer me with very accurate infomation. i know some of the stuff that you were telling me but you gave some more knowledge towards my car and if you ever have a question feel free to ask because i am learnig about this car rapidly. thanks nick
Old 08-12-2003, 08:55 PM
i have spent about 2-10 hours a day on 3si for several years so i do not have many questions but thanks
have fun with your car!
Old 08-13-2003, 09:58 PM
YogsVR4's Avatar
Been on that board for almost four years myself. What name are you on over there?
Old 08-13-2003, 11:08 PM
hey yogs,
yea i thought that name was familiar. i go by the same name both places as well. so if you have been around so long why did you think that the stock turbos were sequential j/k you probably just forgot a "not" in there because everything else you said was right on.
i acctually just found this forum because i am looking for a new car (1G 3kgt with bad motor or tranny or uber high milage so i can get it cheep) i stumbeled here and thought i would give my .02. anyway, talk to ya later,
chris
Old 08-13-2003, 11:11 PM
by the way, you allmost have as many posts here as ipo does on 3si ...post whore
Old 08-14-2003, 09:34 AM
YogsVR4's Avatar
I may have nearly as many here, but the posts in the off-topic forum count here as opposed to the lounge over there. But, its never about the count.
Your right about the turbo setup. I should have read my post and been more descriptive, but you're explanation was leaps and bounds past what I could do
http://www.rtec.ch/turbo_basics.html is one of the spots that has some good basic information (which is about all I know). Great little diagrams in there too.
VR4 ECU vs VR4 CYCLONE ECU pchromiec Galant 1 08-29-2004 10:52 PM
VR4 vs VR4 lol killed a crossfire azn3000GTRacer 3000GT/Stealth 11 05-07-2004 03:24 PM
92 vr4 vs 93 vr4 GreekPower 3000GT/Stealth 10 05-06-2004 10:03 PM
95 VR4 Spyder VS 99 VR4 allen_96er 3000GT/Stealth 14 08-24-2003 10:34 AM
VR4 vs VR4 YogsVR4 Street Racing 10 07-04-2003 01:42 PM
