Go Back   Automotive Forums Car Chat > Ford > Falcon | Fairmont | FPV
Falcon | Fairmont | FPV Australian and American versions. Includes the XR6 and XR8 as well as FPV models like the Typhon.
Old 08-10-2003, 08:34 AM
guitar spice guitar spice is offline
Talking more power from my xf
i was wondering what i can do to my xf to get more power from my standard engine and auto gear box. MONEY IS NO OBJECT. Any help that you guys could give me would be of much help
Old 09-01-2003, 07:35 PM
Trigger351's Avatar
Trigger351 Trigger351 is offline
All the standard things apply with it Gspice:
Up the compression ratio: Keep in mind the crap petrol in Oz.
Run a higher lift cam: Will kill fuel economy.
Make it breath better: Exhaust and intake.
Of coarse if you increase the HP then you have to make sure the drive-train can survive so a shift kit in the auto is a must and maybe a 9" transplant
MUSTANG powered by FORD
http://www.tmaauto.com/
Old 11-05-2003, 04:53 AM
XF 4.1L XF 4.1L is offline
hey mate, i also have an XF falcon...after i'm off my p plates im getting a 5.8L 351 in it so i'm not going to do ne thing to my 4.1 250. but if u want to it would be good to get a set of headers and extractors, if you have a local wreckers you might b able to pick up some for around $100, what extractors do is allows the air to flow alot better out of the exhaust manifold. if i was keeping the 4.1 in my car i would get extractors and headers...well cya later
Old 12-26-2003, 06:06 AM
mr wishing mr wishing is offline
Re: more power from my xf
the 4.1 is a strong engine so you can run good hp through it
get a big cam, extractors with 2 1/2 inch, and get the head done ie ports intake mainifold. first.
thats not to much money but there is so much you can do to your engine before you think of forced induction but it dose get costy
Old 12-27-2003, 05:11 AM
hutcho hutcho is offline
Cool RE: XF go faster
Money no object Hmmmm! Want to build my motor then Just kidding Seen as u got a decent budget first I'd think conversions. V8's make better power & tourque dollar for dollar than a six. Windsor wet wieght not much heavier at all than u're six. Cleveland cheaper to source parts for. Or if you're really into sixes or can't leagely convert to V8 where u are consider a later six price a new BA engine agianst bombing the crap out of a X flow to get the same performace but no fuel economy & reduced reliability price a BA XR 6 turbo engine against turboing & up grading a Xflow to cope. Even an EF engine would make a much better starting bed especailly since u'll be able to aford quility engine managment bits.
But if it's gotta be Xflow (I'd first suggest finding your self a clean TF cortina as a base instead of a falcon??) back too the cross flow: first top end if u got money to burn boost is where its at *TURBO* it port head fit bigger valves mod for screw in studs /guide plates/roller rockers/quality retainers collets/valve springs/ machine head for triple valve springs incase u need em go to town!! O.ring seal head to block use stud kit becarfull of No1 head stud many people brake the block out there. Carb combo or injection up to u're budget, inter coolers blow offs the hole nine yards. Need mapable ignition system.
If its gotta be naturally ass there a DOHC multi valve alloy head made in small volumes for these engines GET ONE! port the crap out of it match port manifold run big tripple webber side draft carbs 45's or 48's depending on head flow, cams to suit & run custom build extractors & 2 1/2inch exhaust all mandrel bent.
Bottom end (for either top end just change deck hieghts & copression ratio's to suit) first make sure u got block with one piece neopreme seal. the get it bored & sleved (there a bit thin in the bores other wise) machined for O'ring head seals & have the cam tunnel line bored & the crank tunnel machined to aceppt a EF crank & a stud kit. gear drive the cam, with a good budget have a steel crank made to EF spec & lightened,use titanium rods & rod bolts at either 200 x flow lenght or longer with custom rods & pistons. Use top quility pistons & rings of u're brand chiose. Have the inside of the block deburred & polished for better oil flow, fit oil restrictors ect
Hell I could go on all night its only you're budget that limits the possable performance gains for any engine so becarfull when u say money is no object
But that's a quick out line of some possable combo's for good budgets but of cause there'll be heaps other's out there too so waist the time to do a lot of research first before u spend anything. Espacially look for people or engine rebuilders that have lots of experiance with using these engine in some form of high performace motorsport. hope that helps a little
wants some more power from my 455 HO fastgoat Classic GTO's (1964-1974) 3 08-28-2004 06:33 AM
Get more power from 325is?... TheSpy007 3 Series 3 05-06-2004 10:53 AM
HELP need more power from the D16y ah789454 Engineering/ Technical 6 08-23-2003 03:22 AM
A4 2.0 FSI: More power from every drop of petrol kak '94 - '01 1 08-29-2002 05:10 PM
More power from D15B twin-carb ? sigh '71-'87 Civic | CRX 4 03-21-2002 03:06 AM
