Old 08-09-2003, 07:58 PM
fredthedragon's Avatar
fredthedragon fredthedragon is offline
Send a message via AIM to fredthedragon
brake caliper problem.
hey is there anything else i can use to grease the slide on my brake calipers? everything i try just f##ks up my rotors again, and currently i can't afford the honda caliper grease.
I'm no street racer nor do want to be, my goal is a fun car... that leaves SUVs in the dust.
current car: red 90-civic-STD-hb
with dx trannie, ecu, shift knob, & rear seats.
i hate my vynil seats.
p.s. i am once again with computer, please forgive the one year leave of absence.
Old 08-09-2003, 08:27 PM
BullShifter's Avatar
If your brake pads are worn w/ grooved/warped rotors, no grease will help that problem.
Old 08-09-2003, 10:11 PM
i know i have brand new rotors and brand new pads and i need to replace them again after i get more money and will be buying honda caliper slide grease. but for the time being i can't afford jack shit and i need to know what people who don't buy honda stuff use to grease their caliper slide. can anyone contribute any usefull information besides taking me for an idiot.
Old 08-09-2003, 10:15 PM
sorry if that came off harsh it's just that i'm having a terrible day, and the dude who said that could know jack shit about hondas for all i know he has a vette.
ok still having a bad day had to cut out many curse words, sorry again.
Old 08-09-2003, 11:02 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I use Lithium Grease.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-09-2003, 11:10 PM
where do you get that?
Old 08-09-2003, 11:42 PM
Sears, it comes in cans that u put in a grease gun. But I'm sure any autoparts store will have a tube of it. Grease is grease, there is no need to pay more because it says Honda on it.
Old 08-10-2003, 06:05 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
use silicon grease. wont lithium eat the rubber up ?
Team Lonely Drivers
Old 08-10-2003, 11:41 AM
Yep I know jack shit about Honda's! Only worked for Honda for a while & now work on them almost every day. I do have a honda, thanks. Better describe your problem & you'll get a better answer.
Old 08-10-2003, 07:27 PM
4thGen4Door's Avatar
4thGen4Door 4thGen4Door is offline
Why are you going to grease the slide on my brake calipers? What does this do? When do ya need to do this? How do ya do this??????
My Breaks are not very good will this help?
Old 08-10-2003, 09:02 PM
Brake inspection/cleaning/adjustment should be done atleast every 15K on Honda's. You do this for the inspections & to lube things. Brakes get very hot & need to move freely.
Disc brake service:
Lift & support vehicle
Remove front tires
Remove caliper
Remove pads & shims
Inspect pads, rotors, calipers
Lube slides w/ silicone grease& pad backing, shims, reatainers w/ Molykote M77
Squeeze piston back in caliper
Re-assemble & spray down with brake cleaner
Disc brake service:
Remove rear tires
Dis-engage e-brake
Remove drum
Inspect drum, shoes, wheel cyclinders, & bearings
Clean w/ brake cleaner
Lube all contact points
Turn clevis(adjusting screw about 7-10 turns, re-install drum & make sure it moves freely.
Re-assemble
You could also add a brake bleed into if it has never been done. start with right rear, left rear, right front, left front.
Old 08-11-2003, 10:46 PM
silicone grease, nice guess i should call pam anderson.
just kidding. i'll prolly go out and buy some silicone grease for my next paycheck. thanx guys.
Front Brake Caliper Problem leejerryj Previa 1 07-10-2011 03:35 AM
front caliper issues 92 maxima aerrick_matthew General Discussion 0 09-28-2009 11:54 PM
My 91 Passat Brakes need HELP!!!! Passatdude '88 - '92 1 05-17-2009 04:40 AM
91 lumina rear brake calipers problem john q smith Lumina 5 01-08-2006 07:42 AM
Brake/Caliper Problem? Help sslandry General Discussion 4 09-30-2004 10:15 AM
