Old 08-09-2003, 03:51 PM
Jim Baker Jim Baker is offline
Fault Code 42
My 92 Cavalier has a problem. The engine light comes on frequently.
When I extract the fault code, it flashes 42, which the Haynes books says is something to do with a connection problem between the computer and the ignition module.
Has anyone out there had this problem and how was it rectified?
Thanks
Jim Baker
Old 08-09-2003, 07:34 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Two things cause this code.
1. A bad ECM.
2. A bad ignition module.
One of the two will cure your problem.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 08-10-2003, 01:01 PM
Ouch! That sounds expensive.
Thanks
Jim Baker
fault codes G. Marquis grand Grand Marquis 2 03-01-2004 02:41 AM
Secondary Air Injection Fault Code camfambmw540 5 Series 1 05-30-2003 08:54 PM
Throttle Position Fault Code 1995superchargedm3 M3 0 12-21-2002 12:48 AM
Is O2 Sensor Fault Code 100% Correct? BETTER THAN A WRX Maintenance 12 06-10-2002 05:25 AM
bluebird engine fault code wanted zefire Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 0 02-11-2002 02:33 PM
