Go Back   Automotive Forums Car Chat > Racing > Street Racing
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-26-2001, 07:30 PM
AlexB AlexB is offline
Send a message via AIM to AlexB
How the heck do they convert FWD to RWD
Well the subject explains my question. I keep seeing fwd cars converted to rwd and I was wondering how the heck it's done.
Thanks!
1996 Z28 M6
Borla Cat-Back
K&N Filtercharger
Hurst Shifter
Old 11-26-2001, 09:49 PM
fastrThanU fastrThanU is offline
Post
A guy that's at a bunch of cruises I go to took a late model oldsmobile, and stuffed a LS-1 into it with RWD. He bought the car, took the body off the frame, bought a chevy S-10 frame etc., hooked up the drivetrain to it, then dropped the body onto it. he mini tubbed the rear wheelwells, and stuffed some big meats under there without modifying the stock wheel opening on the body in any way. from 15 feet away, it looks completely stock except for a few louvers in the hood for cold air intake. it's a dark blue purple color, and is the definition of the word "sleeper"
11.67@117
"plaster your ass to the back glass"
.... put yer motor where yer mouth is.....
Old 11-26-2001, 09:54 PM
Damn that sounds pretty badass. Could you use the stock engine though and just put in a new rear axle and driveshaft etc?
1996 Z28 M6
Borla Cat-Back
K&N Filtercharger
Hurst Shifter
Old 11-26-2001, 10:09 PM
Post
BTW, i believe the car was a 98-99 Alero
i don't think so, as FWD cars have their engines oriented sideways. you'd have to find a way to mount the engine and all the accessories from front to back. then you have to deal with the tranny, hose lengths, wire, and wiring harness lengths. not to mention the throttle linkage, transmission linkage, clutch linkage and setup..... there are probably a host of other problems that are specific from car to car as well. 99% of the time it is more cost effective and performance effective to simply get a frame and drivetrain set up for RWD, and then drop a body on it. i would much rather deal with the frame and fitting the body to it than hand fabricating all the parts to convert a car using it's existing parts.
Regardless, this modification is extremely labor intensive and should only be done if you have a lot of determination and experience with a wrench. If you are going to do this, i'd mod it to RWD with a NON-computer drivetrain to eliminate that hassle, and change the engine over from being electonically controlled to mechanically controlled unless you are confident enough in your computer skills to hack through the programs. modding it in this way is going to make it technically illegal wether it has a computer or not, and wether the emissions are better or worse than before, if it is done on a late model car.
Old 11-27-2001, 03:45 AM
GTS-4 Ben's Avatar
GTS-4 Ben GTS-4 Ben is offline
Send a message via ICQ to GTS-4 Ben
I have seen a Honda CRX, it had the engine put in the rear and changed to RWD. It is pretty Awesome.
SDU Southland Moderator
Old 11-27-2001, 11:47 AM
bluevette74 bluevette74 is offline
Banned
you have to put a new transmission take out the front wheel drive, put a new rear differential, new drive shaft have to adjust your gear box to the new transmission. In other words its way to much work for the satisfaction of rear wheel drive.
Old 11-27-2001, 08:00 PM
Psman32@af Psman32@af is offline
Send a message via AIM to Psman32@af Send a message via Yahoo to Psman32@af
Its more trouble than its worth if you are trying to change a front drive chasis to rear drive. If you like the way a front drive car looks, but want rear drive, get a rear drive chasis that is close to the same dimensions and stick the body on top of the chasis. You will most likely need to make custom mounts to do it though.
Old 08-07-2004, 04:44 PM
veyron 16/4's Avatar
veyron 16/4 veyron 16/4 is offline
had to be a 99' cuz aleros were not made in 98'
Old 08-07-2004, 07:17 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
It depends on teh car how it is done. A popular swap is putting all variations of the 4.6 Mustang motor into Focus's. There is no frame from anothe car used or anything like this for this conversion.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 08-07-2004, 07:42 PM
RedLightning's Avatar
RedLightning RedLightning is offline
Re: How the heck do they convert FWD to RWD
ya but i think ford sells the stuff to change a focus to rwd, that would be easier then normal.
1993 F-150 Lightning
Mods-March UD pullies, Ltngdrvr CAI, Flowmasters, E-fans, and Eibach / Bell-Tech Drop Kit in the garage.
http://www.cardomain.com/ride/2149061/1
Originally Posted by KustmAce
Real emo kids kill themselves.
Old 08-07-2004, 07:46 PM
kman10587's Avatar
kman10587 kman10587 is offline
Send a message via AIM to kman10587
Yep, they do. One of the magazines (can't remember which one) did an article a couple of months ago on a stock Lamborghini Gallardo vs. a super hopped-up RWD Focus with a V8 engine.
Old 08-07-2004, 07:48 PM
that was from Motor Trend, and thats the coolest sleeper ive ever seen.
Old 08-07-2004, 07:51 PM
kman10587's Avatar
Hell yeah, I want that Focus so badly
Old 08-07-2004, 09:10 PM
landyacht's Avatar
landyacht landyacht is offline
Focus V8 VS BMW M5
Was featured on Speed Channel about a year ago...they didn't tell us who won, but they DID say the Bimmer couldn't shake the Focus.
Talk about ZX5.0
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 08-07-2004, 11:15 PM
Amish_kid's Avatar
Amish_kid Amish_kid is offline
I've heard of Integra's either getting the drivetrain from either an s2k or Crv and being make rwd...I wish my car was Rwd . First and last fwd car i'll own.
How the heck do you pull the headlight bulbs out?!! GT500916 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 13 05-11-2005 12:27 AM
How the heck do I take off the kick panel for a 1996 Civic? kn1ghtrydr '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 01-13-2004 10:51 PM
How the heck do I get the rear tranny mount off ? slammedcivicsi '88 - '91 Civic | CRX | Wagon | Shuttlee 6 12-27-2003 08:14 PM
Closed Thread
