Old 01-11-2004, 02:46 PM
kn1ghtrydr kn1ghtrydr is offline
Send a message via AIM to kn1ghtrydr
How the heck do I take off the kick panel for a 1996 Civic?
What's up,
I've got the dreaded CEL on in my civic, and I've read enough to understand how to jump the ECU and read the blinking lights. So I go to get to the ECU on the passenger side... but the panel refuses to come off! I removed the big black plastic bolt which holds the panel to the floor under the glove box, but I can't remove the smaller grey plastic bolt on the side of the panel. I'm pulling on it, but it looks like it wasn't meant to come out. Am I supposed to just yank it out of there or am I just missing another bolt to take off the panel? PLEASE HELP!
thanks,
Jake
Old 01-11-2004, 02:53 PM
95civicCX's Avatar
95civicCX 95civicCX is offline
Re: How the heck do I take off the kick panel for a 1996 Civic?
My buddy had the same problem once man, he ended up kicking it and what do you know, it worked. So my advice would be to kick the shit out of it.
95 Honda Civic CX
SOHC VTEC
AEM High Flow Fuel Rail
B&M Adj. Fuel Pressure Modifier
B&M Fuel Pressure Guage
APEXi Exhuast
Del Sol Shifter
B&M Shift Stabilizer
H&R Race Springs
KYB AGX Adj. Struts
Eibach Pro Control Front Strut Bar
Arospeed Rear Upper and Lower Strut and Tie Bars
26mm Sway Bar
Rear Disc Brake Conversion (4 Tony)
Specialty Products Adj. Camber Kit
16 Inch Quantum Tec Alloys
215/40 Nitto 450
Old 01-11-2004, 04:27 PM
emerge's Avatar
emerge emerge is offline
Send a message via AIM to emerge Send a message via Yahoo to emerge
It's pretty easy to get off actually. The trick is that it has 2-3 slots which slide over little tabs which are under the inner plastic. Try pulling down and then to left. I think thats how I did it. Also, look up further into the foot area (near the front), I believe it bolts on up there also.
Stephen Gladney
Original PH Member
EJ8 Civic | AIM: nxzo | www.rtek.org
Old 01-11-2004, 04:36 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
here's the process...
1. go outside
2. find a really heavy stick/log/branch etc...
3. walk into garage
4. open car door
5. hit panel w/ heavy stick/log/branch etc...
emerge is right, should jus be able to sorta "shimmy" it out.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 01-11-2004, 07:22 PM
Plasmex Plasmex is offline
Send a message via AIM to Plasmex
Slides off.. I dont even use the screws in mine
its like a snaptight model.. haha
97 red honda civic lx sedan b16a w/ Type R head,full headwork Port and polished, ported intake manifold, 310cc RC injectors, ITR cams, Skunk2 adjstable camegears, VAFCII, modified apexi ws II exhaust
Old 01-12-2004, 01:57 AM
chimchim chimchim is offline
Seriously though, pull the hell outta that little plug on the side. It doesn't want to come out... but just make it. It's basically a barbed plug.
Old 01-12-2004, 11:08 AM
H.tech H.tech is offline
Send a message via MSN to H.tech
ok there is two plastic pushin clips i guess you can call them grab a pair of needle nose pliers and wiggle them off . once you get them off pull towards the rear of the car and up at the same time you should get it .
Old 01-13-2004, 10:51 PM
Kinked210's Avatar
Kinked210 Kinked210 is offline
Send a message via MSN to Kinked210
Emerge...i wanna do ur car..its sexy
1996 Honda Civic Ex
D16Y8[SOHC VTEC]; 5-spd
AEM Short Ram Intake
DC Sports 4:2:1 Header
Tsudo N-1 Midpipe
How to remove driver's kick panel-2003 Grand Prix SE reen910 Grand Prix 1 04-24-2009 05:03 PM
how do I take off the back door panel? cbrewer Jimmy 5 04-20-2005 09:15 AM
how do you take off the head unit for a 2000 eclipse mattpenzoil Eclipse 2000+ 1 11-13-2004 06:46 PM
how do i take off the door pannel on my 1992 honda civic? rshrop '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 08-01-2002 05:46 PM
how do i take off the "G20" emblem w/o messin the paint? cliffud General 8 02-20-2002 03:59 PM
