Old 08-06-2003, 09:24 PM
rap123 rap123 is offline
Send a message via AIM to rap123
Unhappy Ruff Idle
My Car is an 92 Eagle talon tsi awd, and I have got a problem. The car has a ruff idle, and sometimes after long use, doesn't start that easy. Its also smelling like its getting a lot of fuel. But I have replaced the O2 sensor, and that wasn't it, if any one on this site knows any related fixes, or ideas on this let me know. [email protected], or just IM me at musclecarskick on AIM. Thanks
Old 08-10-2003, 02:46 PM
assgy
Old 08-11-2003, 01:43 AM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Your idle could be an ISC problem/faliure. I bet you also have the famous DSM hot start condition.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 10-26-2003, 02:53 AM
slackingonthe1g slackingonthe1g is offline
do you have the stock bov or are you venting it that can also give you ilde problems. if you are venting and dont have any fuel management system your ecu thinks your engine is getting more air than it really is causing it to run rich. just a thought.
Old 10-26-2003, 10:38 AM
DSM-Owner DSM-Owner is offline
check your MAF and make sure its getting the connection it needs. This tells the engine how much fuel and spark to deliver as well as many other things. Also, do you have excessive oil consumption????
95 eagle talon TSI AWD
Currently being rebuilt. Victim of CRANKWALK!
95 Eagle Talon ESI
18" konig rims, full custom exhaust, adjustable coil overs, rear strut bar, Cold Air Intake.
AIM = ATX eVo VII
Check Out My Car
Old 10-27-2003, 08:24 PM
Talon007's Avatar
The car will hardly run, if it does at all, without the MAF plugged in.
Chris Clark
www.Talon007.com
Old 10-27-2003, 08:51 PM
not necessarily. I ran my car without a maf and it just burned up oil real quick and gas, and acted as if my spark plugs were 50 yrs old....
95 Eagle Talon ESI
AIM = ATX eVo VII
Check Out My Car
Old 10-27-2003, 11:01 PM
Talon007's Avatar
The MAF plug fell out once on me, and the car would hardly run. If it was on first start-up the car will run fine, but as the engine warms up it will start to get worse.
There is no reason why it would burn oil though, you must have other issues there.
Chris Clark
www.Talon007.com
Old 10-28-2003, 04:18 PM
Re: Ruff Idle
yea my bad, i was thinking of that while typing it something else. The oil cunsumption was my PCV valve. Something got clogged up in it and was eating up oil quick...
95 Eagle Talon ESI
AIM = ATX eVo VII
Check Out My Car
Old 10-28-2003, 08:46 PM
Talon007's Avatar
A plugged PCV valve shouldnt burn alot of oil either.
Chris Clark
www.Talon007.com
Old 10-28-2003, 11:13 PM
well it did, cant explain....
95 Eagle Talon ESI
AIM = ATX eVo VII
Check Out My Car
Overheating & RUFF Idle fltstn Blazer 3 08-05-2005 09:44 AM
93 ford lx surging while driving and ruff idle turtle725 Escort 6 12-18-2004 11:09 PM
ruff idle poor$teen Cavalier 3 07-24-2004 11:31 PM
4.3 ruff idle 88S10Blazer Blazer 5 01-29-2004 06:35 PM
94 2500 5.7 ruff idle zimmlake C/K 0 01-28-2004 09:32 PM
