Old 08-04-2005, 06:03 PM
fltstn fltstn is offline
Send a message via Yahoo to fltstn
Overheating & RUFF Idle
I have had a problem with my 1996 Blazer over heating and idling ruff (HIGH) since I changed the heater core. I have replaced the following;
- Heater Core
- Thermostat
- Water Pump
- Spark Plugs
I can not fully trouble shoot the idle issue because I am over heating. Please Help Somebody...
Old 08-04-2005, 08:40 PM
drdd's Avatar
drdd drdd is offline
Re: Overheating & RUFF Idle
if you haven't already, replace your rad cap with a Stant brand cap. The ACDelcos have known defects.
is your coolant circulating? is the stat opening? does your upper rad hose get hot? is the coolant making it through the radiator?
after changing the heater core, did you refill with the correct amt of coolant?
did u replace your drive belt? does belt tension seem to be okay?
is the overflow reservoir system working properly? can u hear it chuggin' ?
if the rought idle only appeared after the heater core replacement, then go back and retrace your steps. Check all vacuum lines and connects esp in the area where u were working.
- Heater Core
- Thermostat
- Water Pump
- Spark Plugs
Old 08-05-2005, 01:17 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
When the engine is completely cold in the morning, go out and remove the rad cap and see if the coolant is right up to the top of the rad.
Also check to see if there is any coolant in the overflow resevoir.
Replace the rad cap ASAP. And use anything other than an AC Delco.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-05-2005, 08:44 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Definitely change the rad cap asap! I changed mine and right away I noticed the temp staying a constant level. The AC delco one was leaking like a siv and not holding the pressure!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
