Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 08-04-2003, 07:49 PM
salinas salinas is offline
car will not start
i have a 1987 bmw and it will not start the fuel pump is ok 40psi but injecters will not fire,or the coil i think my computer died but not sure could sumone help please.
Old 08-05-2003, 04:49 AM
BMWTECH BMWTECH is offline
Most likely sounds like the Crank Sensor. It is bolted to the front cover of your engine. It picks up a signal from the balancer for cylinder identification, therefore letting the ECM know when to fire. All this if for sure your injectors are not firing and your coils are not firing. Also you may want to check the Main Relay, very common problem on your car. It is either a silver relay or a white relay in the front power distribution box under the hood next to the airbox.
done with oil pan now car will not start jumped it and started smoking? nickfromboston Town Car 2 03-31-2009 07:24 AM
Car will not start. sharkdog Cavalier 1 12-27-2003 07:12 PM
Security light comes on and car will not start vballplayer Alero 1 11-06-2003 04:41 PM
Car will not start Robinson 3 Series 1 10-17-2003 02:57 PM
