Old 08-01-2003, 12:54 PM
Deejay27's Avatar
Deejay27 Deejay27 is offline
Tons of "Pin Holes" with Tamiya Putty
Why am I getting all these pin holes with the use of this putty? I sand it smooth and with close inspection I can see little tiny holes in the putty. I apply it again and sand (ofcourse when it's dried) and the old holes may have been filled but I now have new ones to deal with. What's the deal with that? Are all putty like this?
Jimmy
Current Project
"Tamiya 1/24th scale Enzo"
Completed Projects
"1/12th scale Renault FW14B"
"1/24th scale McLaren MP4/7"
Old 08-01-2003, 02:20 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
Which Tamiya putty?
You might be better off filling the pin holes with a little primer applied with a brush.
SCCA 7, The lost Z
Old 08-01-2003, 03:04 PM
pcmodeler's Avatar
pcmodeler pcmodeler is offline
I have the same problem sometimes. I think it might be old putty.
Old 08-01-2003, 07:21 PM
LamboNut's Avatar
LamboNut LamboNut is offline
What I do is apply a thin layer of super glue over the putty and sand it out
Current project:
Lamborghini Diablo SV
Old 08-01-2003, 07:34 PM
sausage sausage is offline
When applying tamiya putty I usually mix in a bit of gunze thinner to make it less viscous. Since it flows more easily then, I don't have any air bubble problem when it dries.
Recent stuff:
Singapore scale modeling site at http://machinemess.singaporeanimenews.net
Old 08-02-2003, 03:50 AM
jla's Avatar
jla jla is offline
its probably how you mixing it, try not folding the catalyst in, youll just be adding air bubbles
Old 08-02-2003, 04:55 AM
Sennake's Avatar
Sennake Sennake is offline
That's what I do also. Or sometimes I mix some super glue with Tamiya putty, it is smoother and it dries quicker...
* WWW.SENNAKE.BE *
Old 08-02-2003, 05:14 AM
bigfrit's Avatar
bigfrit bigfrit is offline
That's a great trick, I will probably use it also sometime, as I have the same problem...
Olivier
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
