Old 07-31-2003, 09:16 AM
nazmobile nazmobile is offline
FS: Parts left over after SPI swap
From the '96 1.9L :
Most engine parts minus the oil pan, thermostat, plugs & wires, oil dipstick & tube, PCV hose, exhaust mani, flywheel, wiring harness, crank position sensor. HEAD & BLOCK ARE DAMAGED AROUND #4 CYLINDER!
Note: Water pump and timing belt have only 1 week of use!
From the '97 SPI :
Oil pan, accessory bracket, P/S pump (condition unknown), exhaust mani
Let me know what you need and make an offer
Thanks
Old 07-31-2003, 11:44 AM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
Re: FS: Parts left over after SPI swap
Originally posted by nazmobile
From the '96 1.9L :
From the '97 SPI :
Thanks
If your selling the 1.9 flywheel, what flywheel did you use on the 2.0? or do you have a auto?
It's good to know that the 1.9 and 2.0 oil pans are interchangeable, but for some reasone the 91-93 and 93-96 oil pan gaskets have a differnt part #.
I make slow Escorts less-slow.
My cardomain
Old 07-31-2003, 03:59 PM
I used the '96 flywheel, the post says MINUS the flywheel, etc. The only difference between the two oil pans is that the '96 has an exhaust pipe bracket on it that there's no way to attach to the '97.
SPI swap Elyriadave Focus | C Max 4 03-18-2013 04:51 PM
FTO GPX 95 Wheels Swapped Left Side+Racing After Parts SmokeSolid Members Project Cars 15 07-27-2010 10:50 PM
parted out 2nd gen...left over performance parts importguy33 Engine, Transmission and Drivetrain 1 09-11-2005 09:17 PM
Any AC parts I have to change after engine swap? KoHC '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 05-02-2004 06:03 PM
would like to know alot about 2.0 SPI Swap 95scortlx Escort 1 04-18-2004 10:02 PM
