Old 07-31-2003, 03:03 AM
91dx 91dx is offline
AF Cutter
my cars slow?
My car runs boggy in first and second gear. I mean REALLY boggy. I'm guessing a stock anything could beat this for real.
I run a 91dx hb with a b16a motor swap. The vtec works fine, the motor sounds good, but I'm just not sure what the problem with the start off is. It sucks horribly. any ideas? The only problem I know of is the computer flashes 1 red light when I turn it on and that is for the 02 sensor which I don't know if it would cause my car to run SLOW in first and second??? any way thats for the help in advance!
Old 07-31-2003, 03:16 AM
mastarolla mastarolla is offline
Send a message via AIM to mastarolla
slow
are you talking about bogging off the line or about the motor not pulling hard to higher RPM?
Having a failing O2 sensor will make your motor run rich if anything.
Old 07-31-2003, 03:19 AM
AF Cutter
yea I'm talking it doesn't pull hard.. hell it doesn't pull hardly at all :\ and it sounds like it's not getting fuel or its getting to much and choking it out .. you know how when you choke a dirt bike and it runs mopey for about 10 seconds? well same shit here man I dunno but it does it 24/7..
Old 07-31-2003, 04:02 AM
funkdaflex1 funkdaflex1 is offline
My car would bog really bad when I had the o2 sensor out when I had a test pipe on check all your conections make sure your sensor is in nice and tight.
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
Old 07-31-2003, 04:08 AM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
If your O2 sensor is not working than your engine is running on a "limp home mode".
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 07-31-2003, 10:11 AM
AF Cutter
awesome I hope thats my problem
96 Taurus slow cranking bukuballs Taurus | Taurus Wagon 6 06-07-2011 07:25 PM
Caravan only gets to 25mph then slows dieter Caravan | Voyager 4 08-06-2009 06:23 AM
Laguna II 04Reg - Electrical fault ligh and car slow thunnisett Laguna/Laguna II 0 04-06-2009 01:27 PM
Fast cars, slow cars...and everyone in between silentscreams85 Non Specific 3 08-22-2007 09:56 PM
DAMN my car slow!!!! =( My Story hellah fresh Off-Topic 36 06-30-2005 02:08 PM
