Nothcing pistons... How to?
I want to put on my 302 a pair of edelbrock victor jr. cylinder heads but it says that the pistons have to be notched for clearence. Can you guys help me out explain like how to do that and also if I put that on my 302 engine would i later be able to put the heads on a 351w if i wanted to...Because I wanted to improve my performance greatly but not have to buy parts twice....Thanks All in Advance
First off you are aware Vic Jr are way way too big for a 302 unless you going to run a ton of boost.
Also most people who build a motor that needs Vic Jrs are building some type of stroker motor so they just buy new pistons to work with those heads. Yes you can use the Vic Jr on a 302 or 351W, they are designed for a 351W so they use a 1/2" head bolt. To use on a 302 use ARP 7/16" head bolts with stepped washer kit. I can explian to you how to properly notch pistons but unless you have maching equipment its pointless cause you will not be able to do it correctly. So you would be better of just buying new pistons and installing them.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
Not to mention, that in order to properly "notch" pistons, you will need to disassemble the block and remove the pistons. It would be better off left to a mechanist to do the work of notching or fly cutting pistons. Have you looked into AFR heads, they flow very well and would make decent power on the 302.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
yea my plan is to build a 427 stroked 351w so i was trying to improve on my engine now with the stuff i was going to build that engine with....Maybe I will just wait to get it till I start building my engine,
Where might be the best deal to get a short block 427 stroked windsor? What are you guys oppinions on this? |
sounds real nice to me, I want to stroke mine too. You'll have a beast of a stang, what body type is your vehicle?
To start your search on the engine, i'd begin with the engine factory. This is a link to their ford section http://www.fordcobraengines.com/ If i was going to do what you are doing i'd just buy stuff with only the 351/427 in mind, and if it could bolt onto the 302 then bonus, but otherwise i wouldn't preoccupy myself with such compatibility considerations.
free hypsi87!! Dan's White Horse Bring back Melt Crew 002 - 3657 posts can't be wrong! |
Stroked 427 Windsor... Your going to make this a Trailer Queen right?
Tony,
What do you want out of your car?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
what do i want out of my car, Hmm..... about 450-500 rear wheel horses, I want it to have plenty of power and if my friend with his firebird challenges me then Sianora for him.... So if you know how i can build a Small block with that much power to the wheels and it is a better and easyier please let me know....Bigdan it is a 70 convertible, GtStang remember the saying no replacement for displacement.
well how much do you suppose a strocked 351 could produce? It seems to me that his hp and torque aspirations could be met very easily with little aftermarket improvement.
Here is the only thing about a 427 stroker Im commenting on. That combo is really pushing the physical limits of that block. It is really mostly used by full on race cars. They do not expect to get 100.000 miles out of the motor. Thet are happy if it last one season. Most who go that route also start with a fresh FMS 351W block cause its the only chance you have to make it last. If you really want a stroked windsor go 393 or 408 much safer.
For the HP levels you want you dont need all those cubes. You can use a 302 blower combo and get it. If you want NA then stroked windsor would be good also. Give it some more thought and ever one here will help you out. Hi-Flow.... This weekend Worcester Burn-outs. Im gonna give my new axles all they can handles come check it out.
Tony,
Look at my sig, there are not too many cars that will have that much HP out there. Its a simple 302 with an S-Trim, my heads are not the best, so there is big room for improvment there. GTStang, What do know about the Cobra 351w upper and lower used for a stroker? Would that intake be better suited for a 357? That is the intake I have in my garage right now, with my 20 over 69 block. Who did you go through to get yours? Or did you piece your together? I want something that is going to be able to hold 650hp to the ground I was told go with a scat 393, but I have not heard if the combo would be conducive with the cobra intake. Thanks for any help.
ok so you guys think having my 302 and puting like maybe the Edelbrock Rpm heads and Rpm Manofold with a street demon 650-750 cfm carb and posibly a blower (The Centrifical kind) would it be better for reaching my desired power? Any suggestions or parts to use instead of these....O yea thank you so much for the help
Doing a carb with a Centri Supercharger would be a pain in the butt. Your better off the a roots style.
Now if you go EFI, Cenri Supercharger would be fine. Are you keeping the carb, no matter what?
well I would like to keep the carb...And i would like all the stuff under the hood...I would love to put the roots type on it that would be awesome sounding but I was reading and saw that if the carb was not perfectly tuned for it, it could like explode or something...maybe you guys can explain it to me alittle better.
