Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-29-2003, 09:26 PM
00tegGsr 00tegGsr is offline
B18C turbo
I need to know how much boost stock sleeves on a B18C1 will hold. I have JE 9:1 comp pistons standard bore, with crower rods, cometic head gasket, and a block gaurd. I am running an intercooled T3/T4 setup. My fuel management consists of an intank fuel pump 255lps, 440cc injectors, super afcII, aem fuel rail and FPR with a vortec FMU. I want to know max boost the sleeves will handle if I were to run race gas. Also how much boost the stock ecu can handle before failure.
Old 07-30-2003, 08:03 AM
integragsr98 integragsr98 is offline
I think they handle up to 13-14lbs, anything over 14lbs, you will have to resleeve it. With a SAFC II, you don't need the Vortec FMU. Get a missin link map sensor to overide the check engine light...i might be wrong..correct me anyone.
xtremetuners.com
Old 07-30-2003, 05:21 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
You are right as long as the safc is tuned properly...
JDM b18c TURBO help skiclouds JDM Motor & Parts info/chat 4 10-11-2005 11:41 PM
b18c turbo crx teg94 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 08-04-2004 10:51 PM
b18c turbo?? b16aturbo Forced Induction 4 03-02-2004 09:15 PM
b18c turbo?? b16aturbo Let's get Technical! 0 03-01-2004 12:34 AM
