Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 07-28-2003, 12:00 PM
vtec28412 vtec28412 is offline
Send a message via AIM to vtec28412
Ground Control coilovers
I just ordered some GC coilovers and I was wondering what would be some good shocks to go with those and when will my stock shocks give out? And has anyone had any problems with them at all? Thanks
Old 07-28-2003, 09:23 PM
94civic's Avatar
94civic 94civic is offline
which version did you get. they have a version for the tokiko's and they have a version for the koni/kyb. if you got the tokiko version then go with some tokiko illumina's if you got the koni/kyb version get some koni yellows. i had my GC's for about 8 months and i haven't had a problem with them the ride was pretty good until my shocks blew out like a month ago(tokiko blue's are no good for dropped cars). instead of replacing the shocks i'm just going to go with a full coilover setup.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 07-28-2003, 10:36 PM
BullShifter's Avatar
Cancel your order
Go with true coil-overs or spring/shock -- no sleeve springs
H&R's Cup Kit is a nice deal -- matched shocks & springs -- H&R also has sweet coilover set-ups.
KYB-AGX does NOT recommend using them with sleeve coilovers
Old 07-29-2003, 02:03 PM
I really really wanted some tein coilovers, but I don`t have nearly enough money. I wanted something reliable and inexpensive.
Old 07-30-2003, 12:14 AM
IMO you should have went with spring & shocks, but its your $$$ & car do as you please.
Old 07-30-2003, 01:40 AM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
Darrell
thegrumpysergeant.net
Old 08-25-2003, 04:26 PM
SiXPuSHA SiXPuSHA is offline
Send a message via AIM to SiXPuSHA
Why springs and shocks over coilovers and struts?
Some Stupid mazda that's ALWAYS BROKEN!
Slow as hell and twice as ugly!
Old 08-25-2003, 10:39 PM
coilover sleeves suck
Old 08-26-2003, 09:15 PM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
Heres the issue.
For the cost of a good set of coilovers now, there is really no reason to save up the 700-1000$
The only good reason to go with CG coil sleeves, or Skunk2 is because you can order custom spring rates and length.
However the only OTS shock capable and warranties with these is the Koni Sport shocks, and for the cost of both you could have a coilover setup.
Autoxers like the CG, koni yellow setups because you can specify your specs for the springs. I have myself seen how capable these setups can be.
If you don't know spring rates, don't race, don't bother with CG, Skunk2 or Koni yellows.
M.Sanew - AutomotiveArticles.com
Old 10-11-2003, 12:05 PM
99_CivicSi 99_CivicSi is offline
Re: Ground Control coilovers
I installed Skunk2 springs on my 99 Si using the stock shocks.. They are awsome, the ride is good, lowered about 2.5 inches. I used SPC control arms to adjust the camber.
If you want to start with something inexpensive, I would go with the Skunk2 springs, I picked them up for $169.99 shipped.
Old 10-11-2003, 05:19 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I've been killing people with my Ground Control coilovers with Koni Yellows against people who have "real" coilover systems in autocrossing. Problem with "real" coilover systems is that in most cases you cannot order custom rate springs which makes a world of difference.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 10-11-2003, 09:18 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Most cases, or most companies? With Tein ANYTHING is possible with spring rates and shock valving adjustments. I just got done orsering +2kg springs for my Teins and they feel great! I'm now running SS model with the stiffness of the HA model. You can order them with any spring rate you want in 1kg increments and can get the shocks revalved according to the springs rqtes you order for them if they are greater or less than 2kg differance from standard rates for the model used. Best thing is, a spring upgrade only sets you back $50 per shock, and revalving is $100 per shock. Not too shabby.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 10-11-2003, 09:29 PM
Cali Guy
I agree with CivicSiRacer though on the G/C and Koni Yellow combo. If I hadn't gotten my Teins, that's most likely what I would have gotten. But I got the Tein because it was supposed to be a smoother ride, plus it would have worked out to about the same price, minus maybe like $100 or so for the combo setup. Figure $300 for G/C's and $500 for well priced Yellows. That's $800 right there for shocks and springs, which is only $50 less than what I paid for. Of course naturally the smart thing IMO was to go with the Teins since the shop I got mine from sells them for $850. Sure the combo would have been great, but at least I have shocks with valving perfectly matched to the springs on them, and that's what I was going for as I know that can make or break the comfort aspect of my ride which I needed to preserve, or wanted to rather.
hessemer69 on AIM
Ground Control Coilovers or Eibach springs AlwaysMovin '88 - '91 Civic | CRX | Wagon | Shuttlee 13 01-30-2004 05:21 AM
Ground Control Coilovers ? Alexxn 00 Si Tires and Wheels 10 10-24-2002 06:12 PM
Ground Control Coilovers, do i really need Shox? AlexusVTEC Accord/TSX/Accord Hybrid 1 07-15-2002 05:47 AM
Ground Control Coilovers /Koni Yellows RTF247 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 08-28-2001 04:25 PM
