Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 07-27-2003, 08:46 PM
config's Avatar
config config is offline
Send a message via ICQ to config Send a message via AIM to config
Suspension Questions?
1. What has better comfortability? Springs/Shocks or Coilovers?
2. How hard are springs/shocks / coilovers to install? How much is it to get them installed professionally?
3. What are currently the best combo of springs / shocks? Second best?
4. What are currently the best coilovers? Second best?
5. Can i see pictures of your ride, and you tell what kinda suspension stuff you got?
Thanks a lot
1996 Integra GS-R
________________________
• AEM Cold Air Intake
Old 07-27-2003, 09:30 PM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
1.)Why do you want to upgrade?
2.)How much do you want to spend?
3.)How will you be driving your car? (Street, track?)
4.)Is this your daily driver?
5.)Do you know suspension basics?
M.Sanew - AutomotiveArticles.com
Old 07-28-2003, 01:35 AM
config's Avatar
1. because i want 17''s.. and stock suspension+17''s looks like ass.
2. Whatever it takes.
3. Street
4. Yes
5. Yes
1996 Integra GS-R
Old 07-28-2003, 02:07 AM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
Re: Suspension Questions?
1.) springs/shocks wayyy more comfortable than coilovers. you'd DEFINITELY want aftermarket shocks if you got coilovers (the sleeve type anyway), cuz coilovers will blow your stock shocks ASAP
2.) shocks/springs are easy to install.. takes like 2-3 hours for the front and 1.5-2.5 hours for the rear if its your first time. professionally installed they have better tools (i.e. impact guns) and lots of experience so they'll get done quicker. be at least 3 hours though, so 3 hours * $70/hr = $210... soooo worth it to do it yourself.
3.) get some eibach sportlines with koni yellows.. good combo.
4.) tokico illumina coilovers are about $800 and they're adjustable. tein flex are also very good. i dont have experience with either so i cant say which one is better, but they're both very very good.
Old 07-28-2003, 02:19 AM
BullShifter's Avatar
Forget about sleeve type coilovers
True coilovers adjustaded correctly will have a better ride than spring/shocks
Always a good idea to replace shocks when adding performance springs
How low do you wanna go?
Tein & H&R have nice coilovers
**H&R's cup kit** is a nice matched spring/shock kit
Eibach / Neuspeed / H&R good springs
Tokico, Koni, KYB for shocks
If you plan on street driving, I dont see the need for adjustable coilovers. You'll never use them for what they are for . . .
www.tirerack.com
Old 07-28-2003, 03:09 AM
config's Avatar
What are they primarily used for>?
1996 Integra GS-R
Old 07-28-2003, 03:14 AM
Racing - adjustments
Old 07-28-2003, 03:40 AM
config's Avatar
Ok, well im thinking im gonna go with springs/shocks anyway, due to the fact that coilovers need so much tuning etc, and from what ive heard they just seem to be a lot more of a hassle, and have worse handling/comfort etc.
Ok back on track of thread
1996 Integra GS-R
Old 07-28-2003, 03:48 AM
true coilovers have the best handling/performance
sleeve type would be the worst
Old 07-28-2003, 03:57 AM
config's Avatar
Can i buy true coilovers, have some place install them, and be done? Or is there much tuning etc involved... ?
1996 Integra GS-R
Old 07-28-2003, 04:22 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Tuning? no way! I have Tein SS coilovers on my Civic and when I bought them, I had a shop install them for me, and that was it. The shop I went to, the owner said he'd "adjust" some stuff for me to make it more responsive, but I wonder if there was really much else done besides the install. Anyways, the only tuning required is setting the proper ride height of the shocks (talking TRUE coilovers, here) which should set the with the lowest point of the car 90mm from the ground. Your car it might be your bumpers or exhaust, on my car the resonator to my exhuast is the lowest point. The shop would do all that adjusting for you though providing they pay attention to what they are doing. Only tuning you ever have to do is maybe dampening adjustment if you choose to adjust it (not required though) say if you want stiffer handling, or want to soften the ride up a bit comfort wise. That adjustment only takes a matter of seconds, and all you need to do is pop the hood to adjust the fronts, and have access to the shock tops in your trunk area. I did this by cutting a quarter sized hol about 3/4 of the way around to create a hidden "flap" that i can pull back to expose the strut tops for quick dampening adjustment of them. I can have all 4 of my corners on my car adjusted from stiffest to softest in about 30 seconds.
And Jackasssi is correct, I can tell you from first hand experiance, true full coilovers DO infact have the best handling and comfort since the valving of the shocks they come with is specifically matched to the rates of the springs, so one won't out strain the other as would happen when you mix typical shocks and seperate springs together.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 07-28-2003, 09:38 AM
seems to me that you should stick to a good set of springs & shocks.
each time the vehicle is raised/lowered on coilovers, an alignment is recommened.
The age old suspension question piscorpio Tires and Wheels 18 12-26-2001 07:54 PM
P10 "T" Model Suspension question Blue94G20T Suspension 6 10-11-2001 02:21 PM
P10 Suspension Question endfro Suspension 6 08-09-2001 03:10 AM
Suspension questions quanl Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 07-20-2001 01:21 PM
Suspension Question for P11 Nismoboy1 Suspension 39 04-18-2001 02:41 PM
