Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 08-22-2001, 04:27 PM
Blue94G20T Blue94G20T is offline
P10 "T" Model Suspension question
Besides the stiffer springs, what else is different between the P10 touring model and the luxury model? Are the struts/shocks the same? Thanks!
Ron
1994 Blue G20T
ShigSpeed Coilover, 17" Dronell TS05 wheels
Old 10-10-2001, 03:04 AM
AZP10 AZP10 is offline
I have a 96 "t", and I thought the only difference was pretty leather, a spolier, and lsd, thats all I was told.:frog:
Old 10-10-2001, 06:57 AM
P10DET's Avatar
P10DET P10DET is offline
Re: P10 "T" Model Suspension question
What I've been told is that the "t" model got the suspension from the 91-93 models, while the 94+ base models received a softer suspension.
I suppose one of these days I should look at the fiche to confirm this.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 10-10-2001, 10:25 PM
P10DET's Avatar
Re: Re: P10 "T" Model Suspension question
OK, I checked the fiche and was quite surprised......
There is no difference between the base and t models as it relates to springs. This is contrary to what has always been stated on the SE-R Mailing List.
George Roffe
Houston, Texas USA
00 328i
Old 10-11-2001, 01:00 AM
GtRider GtRider is offline
Send a message via AIM to GtRider
springz
so all p10 springs are the same?
Old 10-11-2001, 07:48 AM
P10DET's Avatar
Re: springz
Not exactly. The fronts are different if you have a manual gearbox or a slushbox, but the same part numbers are used for all years and models.
The rears changed through the years. I don't know what is different about them however. I can comfortably say (assuming the fiche is correct - not always a correct assumption) that there is no difference between base and "t" model springs.
George Roffe
Houston, Texas USA
00 328i
Old 10-11-2001, 02:21 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Re: Re: springz
Yeah, I found this out too. I noticed it when I traded in my 94 auto for a 95 5-spd. I had pulled the ground controls off my 94, left them adjusted (didn't figure i needed to change anything), put them on my new car, and after installing everything I noticed the front was about 1/2" higher than the rear! I just figured it to be the difference in weight between the auto and 5-spd transmission. I heard the auto is somewhere around 80lbs heavier? I'm also thinking that is why the intrax springs were quite a bit lower on the front of my old car, they were designed on a 5-spd, and didn't take into account the heavier front end on the auto? Maybe?
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Colorado sport model suspension lift help ljip Colorado 3 07-15-2005 10:57 PM
'94 Legacy Outdoor TI....unusual model? Suspension Problems? ChrisinNH Legacy / Liberty / Baja 1 10-15-2004 04:43 AM
Intrax Springs on a P10 non "T" model CanadianG Suspension 31 12-03-2001 10:48 AM
P10 Suspension Question endfro Suspension 6 08-09-2001 03:10 AM
P10 Automatic Motor Mount Question 240ztt Engine 6 08-06-2001 10:46 PM
