Old 07-25-2003, 03:16 AM
Fire Phoenix Fire Phoenix is offline
Question automatic to manual
is this possible, or am i stuck with automatic transmission?
Rise above it
Old 07-25-2003, 11:43 AM
CB91StangGT CB91StangGT is offline
Send a message via AIM to CB91StangGT
Oh it is possible, very possible...
1991 Mustang GT Conv: 60,000 original miles, 2nd owner :banana:
Built AOD w/2800rpm stall, 3.73's, aluminum d/s, 2 chamber Flowmasters, BBK shorties, 65mm tb, 73mm maf, subframe connectors.
1990 Mustang LX Conv 25th Anniv: 50,000 original miles, 2nd owner :banana:
2 chamber Flowmasters, o/r h-pipe, Pro 5.0 shifter.
Old 07-25-2003, 12:03 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Yes, it can be done, anything is possible. You will of course need a 5 speed tranny, clutch, bellhousing, pressure plate, throwout bearing, driveshaft (although a AOD d/s will work, just not recommended), pedal assembly, umm oh yeah and a shifter. I think I'm still forgetting something, but I'm sure someone else will chime in if I did. You can do the swap yourself, but it may take some time to do so. If all goes well and you pick stuff up used, I can see you spending about $600 for the parts, or up to $1500 depending on tranny.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-25-2003, 08:08 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
The worst part is the install of the pedal assembly. You dont have to but you should change to a Manual Computer.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-25-2003, 11:48 PM
HiFlow5 0's Avatar
Stanger
Right, an manual car can run off a auto's computer, but will be a little rich. An auto car cannot run off a manual's computer.
-2013 Ford Flex
-1999 Ford F150
Old 07-26-2003, 12:44 AM
vbrpete vbrpete is offline
Unless it's mass-air.Then they seem to readjust after about an hour and all's well.
You'll need to modify the trans crossmember as well.Just cut the tack welds that hold the tubes to the frame.The frame will then be free to slide back and forth.Bolt the package in,and once it's settled,re-tack the frame to the tubes and you're done.
Old 07-26-2003, 10:06 AM
rerun rerun is offline
computer??? he has a 69, i have a 67 and i'm doing the same thing (cept mines down to nothing now) there should be in yours(maybe not) a hole that can be punched out for the clutch in the engine bay, and you will need everything else they said, and its just more work then anything else.... but majorly worth it
Old 07-26-2003, 11:25 AM
HiFlow5 0's Avatar
Stanger
Very true, I guess I'm more use to it being done on late model cars. It should have clicked seeing he has 69 Mustang on the side bar for vehical.
-2013 Ford Flex
-1999 Ford F150
Old 07-27-2003, 04:31 AM
GTStang's Avatar
Stang Guy
My bad also Im use to late model. It depends what standard tranny you what to use. If you were thinking T-5 many kits are made but it is also the most difficult as compared to other Ford trannies that were put in Stangs of those years
Old 07-27-2003, 09:09 AM
ugly kid jon's Avatar
ugly kid jon ugly kid jon is offline
So for my automatic, if I want to strap on a Tremec, where would I plug the harness? would the computer run on closed loop?
Old 07-27-2003, 06:45 PM
Carguy393 Carguy393 is offline
I also heard that you have to change the coolant lines over for a manual
If it ain't broke it should be!
Old 07-27-2003, 10:48 PM
There's no computer controlled functions on an AOD,or on any trans in any 1979-1993 Mustang 5.0.The only wiring is the harness for the neutral safety switch and back up lights.There's also the VSS on the side of the trans that also runs the cruise control.
The stock trans cooler lines come out with the AOD.Unplug 'em from the rad and plug the holes(or it'll drip for a month.)
Old 07-27-2003, 11:12 PM
mustangman66cpe mustangman66cpe is offline
The only real challenge of doing this conversion is getting all the linkage from the clutch pedal to the clutch arm. If you dont have a manual or diagram that shows all of these connections, get one! It will save tons of time. Besides that problem, everything should be relatively easy.
Old 07-27-2003, 11:21 PM
And on a '69 it should be VERY easy to get all of the conversion parts either brand new(from NPD or whatever) or from a Mustang specific salvage yard.Some even sell complete changeover kits.
Old 08-03-2003, 08:16 PM
What would It take to do this conversion on my 91' 5.0?
Manual vs auto yazzagaffix Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 09-15-2009 05:45 PM
AutoMatic-Manual VenomRacing Cavalier 4 10-12-2004 11:59 AM
automatic/manual tranny conversion murret-san '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-28-2004 02:52 PM
automatic manual transmision conversion? c32b1 NSX Let's get Technical! 3 02-10-2004 09:54 PM
Automatic manual. chris26969 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 10-22-2002 01:04 PM
