Old 07-24-2003, 11:03 AM
amcinerney amcinerney is offline
1999 Silverado
99 Silverado, 4x4 4.8 V8 with 88k. Occasional (10 times in 4 years), I get what amounts to disengagement of the tranny at idle.
I've been stopped at a light or sign, attempt to pull out, only to have nothing, but in a split second, I get momentum. Not a slapping of the tranny, just "nothing", then you can feel the slight engagement and its fine. This is very intermittant, but odd. My brother in-law's Tahoe did the same thing.
I also have a very fuely smelling startup. Doesn't give a problem starting, just notice raw fuel smell.
At 88k, what detail of tune up should I be looking at? Running ok, but could be much better.
Thanks for any input.
Old 07-25-2003, 02:57 AM
glamis_rides glamis_rides is offline
i have the same problem, it happens about once in a blue moon, maybe 1 or 2 times every 2 months. its like its not moving and gets caught. i have already had my tranny rebuilt, and it has been serviced and it is fine, and then my rear end has also been replaced and that shouldnt be the problem, so im curious if anyone knows what might be causing that.
Old 07-27-2003, 05:40 AM
Gavin Curtis Gavin Curtis is offline
AF Premium User
Error light
There is quite a bit of communication taking place between seven computers in your truck. This problem could be related to data packet errors between the engine and transmission computers. ABS computer error may also cause transmission errors.
Is there by chance any error or warning lights such as the engine, ABS or other illuminated?
Old 07-28-2003, 11:11 AM
Have never seen any LED, there are also no codes being written, I've had them checked. It's freaky. It just happend again this morning, backing out of my driveway...
Old 09-23-2004, 06:30 AM
smbhollifield smbhollifield is offline
Re: 1999 Silverado
I had this happen to me 9-21-04, very weird, I was stopped at a light and it did exactly what you said your's did. I drove straight home and checked the fluid level and it was ok. Not sure what the deal is. I have a 99 2wd, 83k.
Old 11-03-2006, 11:51 AM
whitecloud whitecloud is offline
Re: 1999 Silverado
fuel pressur regulater, drivers side motor on the fuel rail, pull the vac line if there is gas in the line replace about $50.00 at auto zone, runs like new
Old 11-04-2006, 12:18 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Re: 1999 Silverado
HOLY OLD THREAD BATMAN!
*Under Construction - New sig to debut*
Old 11-07-2006, 02:31 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: 1999 Silverado
It is not the fuel presure regulator.. I have replaced that for other reasons and I did still get the same syptoms they are talking about.
It is almost like it is trying to start in high gear or something then shifts down after a sec or two.
I agree, I think there is a communication error between the tranny and the engine.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 11-09-2006, 12:24 PM
92-silverado7.4's Avatar
92-silverado7.4 92-silverado7.4 is offline
ToeKnee
Re: 1999 Silverado
My friend gets the same problem in his silverado, but it only happens when he doesn't warm up the truck
will a transmission out of a 1999 silverado fit a 1999 tahoe upinstyle2 Tahoe 3 11-18-2009 07:16 PM
1999 Silverado hard to start when warm blangan C/K 11 03-18-2009 04:35 PM
1999 Silverado Airbag Light. jaynjessica Silverado 7 07-09-2005 10:33 PM
1999 Silverado DLR not working Sniper57 Silverado 1 06-03-2003 08:36 PM
1999 Silverado 4.8l Has 133,000 Miles cprx1994 Silverado 1 08-24-2002 04:34 AM
