Old 07-23-2003, 09:37 PM
youngdrifter_x's Avatar
youngdrifter_x youngdrifter_x is offline
Send a message via AIM to youngdrifter_x Send a message via Yahoo to youngdrifter_x
Spray paint or Air brush
What is better? I've used spray paint for all my models. And sometimes it comes out weird. it comes out all bubbly. I'v never used air brush. So in your guys opinion whats better.
Old 07-23-2003, 10:24 PM
(_S200_)'s Avatar
(_S200_) (_S200_) is offline
the reason your getting bubbles is becase you are spraying too close or a too heavy coat...try to spray farther away or heating the can helps...
Old 07-23-2003, 11:17 PM
i know that problem already. what i mean, is that its not smooth.
Old 07-23-2003, 11:20 PM
reveller reveller is offline
As a famous phrase goes, the problem isn't the tool but the artist. You cannot say one is better than the other because it takes practice to get a good paint job spraying out of a can or with an airbush. But airbrush is good if you want to do more complex paint schemes which require fine tuning of the spray pattern.
However, if you are just painting something simple, spray cans are the way to go and you don't need clean up after painting.
Hope that helps
reveller
Old 07-23-2003, 11:25 PM
what if i wanted to paint the body with the bumpers and stuff like all the big stuff? and for the little stuff what can i use? paint markers?
Old 07-24-2003, 04:25 AM
chipanggo's Avatar
chipanggo chipanggo is offline
to answer your question: it depends. but most of the time i use airbrush. it's easier to control than paint cans. however the drawback of an airbrush is the initial investment. although in the long run, the airbrush pays for itself.
Old 07-24-2003, 04:32 AM
Focus2000's Avatar
Focus2000 Focus2000 is offline
Evil Genius
For the little stuff I'd recommend enamel paint, using a variety of brush sizes and sometimes toothpicks for the very small details.
Spay cans should be fine for bodies/bumpers. Take a look at primeraman's stuff in the gallery, he uses cans and you'd be hard pressed to pick faults in his work! You probably need a bit more practice on your technique.
Chris
Old 07-24-2003, 05:57 AM
primera man's Avatar
"P-Man"
Here are a few links you may want to read
What kind of airbrush should I buy?
Do I have to buy an airbrush?
Why is an airbrush better than a spray can?
What can I use as an air supply for my airbrush?
View All My Models Here.
Old 07-24-2003, 10:08 AM
so what your saying is that air brush takes longer, but the finish comes out better. toothpicks? i'll have to try that.
got a new air brush.. what kind of Air Compressor do i need? Hustle_187 Car Modeling 2 04-14-2005 10:28 PM
Clarify an air-brush painting phenomenom please spidereddie Car Modeling 6 02-12-2005 03:09 AM
For those don't have air brush, how many spray can you use painting a model? yellow15 Car Modeling 28 07-05-2003 09:12 PM
Cheap Air Source for AIR BRUSH dudez316 Car Modeling 4 06-03-2003 11:13 PM
For those using Tamiya spray paint for painting car body Ben L. Car Modeling 5 08-08-2002 05:53 PM
