Old 08-07-2002, 12:26 AM
Ben L. Ben L. is offline
For those using Tamiya spray paint for painting car body
On average how many can(s) do you use for such task? Any tips on doing a decent job with spray cans? I read a thread where Primera Man outlines the steps he undertake when painting car bodies, but I can't find it now. Can someone please post the link? Thanks.
Old 08-07-2002, 05:13 AM
Purpura Delujo Purpura Delujo is offline
How do you get a really good finish? You get your brother who has been spraying....all sorts of things and who is rated as one of the best painters in his area to do it for you Well, at least thats what I do...
Old 08-07-2002, 05:54 AM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
cheater
J/k.
Old 08-07-2002, 09:07 AM
primera man's Avatar
"P-Man"
Re: For those using Tamiya spray paint for painting car body
This it here you looking for??.......
Make sure you sand the car well...removing molding lines etc. Finish off with 1200 grit paper.
Before painting, heat the can up in hot water for 10 minutes so it flows better from the can.
2 Coats of white primer. First coat very light, the second so that it covers the model. Dont be to fussy if it still looks a bit "see-though"
Leave for a week to harden the primmer.
3-4 Coats of finish coat about 5-10 minutes apart....thats it...nice a simple.(keep the can warm)
The first coat is a vey light mist coat...the paint should only just be landing on the car.
Do the same for the second coat
The third coat you can spray a bit more heavy.
The last coat is the one you want to get perfect.
I always spray the front and rear bumpers first...then both sides along the whole length of the car body.
Then the last bit i do is the bonnet/boot and roof last
Dont bother sanding between coats as i dont really see the point...all you are doing is making more dust and removing half the paint you have just stick on.
After you have finished the last coat...leave for 10-12 days.......rub with some compound then finish with a wax.
After one day....leave the car in the sun or a warm place to harded the paint untill you polish it up.
View All My Models Here.
Old 08-07-2002, 09:55 AM
primera man - Yes! That's what I was looking for, thank you very much for the repost.
turmio - thanks for the link too.
Old 08-08-2002, 04:53 PM
mediamixhobby mediamixhobby is offline
Re: Re: For those using Tamiya spray paint for painting car body
Hi P-man!
A silly question: what's the temperature to heat the can at? I always afraid the water is too hot and make the can explode!
MediaMix Hobby
http://www.mediamixhobby.com.sg
Should I use primer under Tamiya spray paints? lotus123 Car Modeling 3 02-28-2009 10:16 AM
Car Body Modifications Beetleman General Issues 1 02-22-2009 03:28 PM
Ok to use Testors primer w/ Tamiya spray paint asaenz Car Modeling 20 04-29-2004 09:00 PM
Question anout Tamiya semi-gloss black spray paint for the body. (ive done a search) MEKANIK Car Modeling 3 09-15-2003 04:45 PM
For those don't have air brush, how many spray can you use painting a model? yellow15 Car Modeling 28 07-05-2003 08:12 PM
