Old 02-11-2005, 03:20 PM
spidereddie's Avatar
spidereddie spidereddie is offline
Send a message via AIM to spidereddie Send a message via Yahoo to spidereddie
Clarify an air-brush painting phenomenom please
I painted a little this weekend (first in a long time) and I was very disappointed. I was spraying and I realized that everything was coming out in a grany, sandy texture (even if I applied heavy wet coats). I thought it was dirt so I made sure to clean well for the next part, but same result. after some sobbing and searching I realized that it was probably the fact that I've diluted all my paints (model master and testors acryl) with rubbing alchohol. From what I've read this is the typical presnetation of trying to paint with acryls thinned with this stuff. Is this true and if not what can you guys suggest? I just got a brand new head/needle/nozzle set up for my badger. What should I do
Ed-
Old 02-11-2005, 03:29 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Re: Clarify an air-brush painting phenomenom please
You might be thinning the paint too much, and it's drying before it hits the surface.
I have the Testors modeler's guide on PDF, I can send you the airbrushing section when I get home if you want.
PS: I'm finding the Acryl doesn't need much thinning, if at all.
Old 02-11-2005, 04:24 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
It's not the airbrush, it's the paint/thinner.
I use lacquer thinner to reduce my acylics for airbrushing, but never put any lacquer thinned paint or lacquer thinner back in the bottle, it'll turn it all to snot in a day or so... - Mark
Old 02-11-2005, 06:30 PM
SchuberT's Avatar
SchuberT SchuberT is offline
Lacquer thinner? I never would have though of that. I'll try that next time I spray acrylics. Thanks for the tip.
Read the FAQ please.
https://www.facebook.com/KBModelwerks/
Call me Matthew.
Old 02-11-2005, 06:44 PM
ZoomZoomMX-5's Avatar
I know it works for Tamiya acrylics, does it also work w/Testors Acryl? Acryl doesn't like to be thinned w/it's own product...it's better unthinned, but if lacquer thinner works it would spray a bit easier.
My Fotki Album
Old 02-11-2005, 10:03 PM
Some guy on the Scale Auto forums asked a 'guru' one day and he said he uses distilled water to thin Acryl, about a 70:30 paint:thinner ratio, and he sprays in light coats, very close, within a couple inches. I tried some semigloss black without thinning on some drapery hooks for my mother, and it worked great.
Old 02-12-2005, 03:09 AM
proosen's Avatar
proosen proosen is offline
I never had any problems with acrylics and alcohol in any form, that is Tamiya's acrylics. But laquer thinner is good to, gives the paint a little more "bite". Don't try to thin anything but acrylics with alcohol though as it sure will make a mess of the paint. This kind of problem can occure with enamels if the thinner is to weak, I had problems with white spirit and Humbrol. The paint became all grainy and unusable, a little laquer thinner took care of that problem.
Good luck!
Niclas
