yeah while im driving i can feel a blast of hot air coming from under the dash or console onto my foot thats on the gas pedal..also i can feel the heat on the shifter console and where the e-brake is?...any help..suggestion??????????
hey man i know how you feel i have the same thing goin on in my car, so i wanna know the same thing
94 honda civic dx d154b7 pacesetter header btm stage 2 clutch c.a.i short throw shifter altezza's gauges and bezel interior painted dropzone coilovers with 2" drop 205/40/16 yokahama parada's 99 honda civic ex vtec dc header c.a.i dual tip muffler |
do you happen to have any big holes in your firewall. not too likely but maybe its rusting from the engine bay or underneath around the ebrake?
97 civic hx -------------------- mod list: CAI, 17" wheels but now removed and much more to come. not much of a list yet really |
Not to be a smart ass, but did you check to make sure you don't have your heat/ac turned on? If your air is off, turn the hot/cold selector to the cool end, and hopefully you'll just feel normal outside air coming in.
hah..yeah my AC is off..i actually dont have AC right now...and its turned to cool...but i did do a auto to manual swap when i swapped the engine so they cut into the firewall there. but i dont think its coming from the area the cut it from...i think that heat would come from the clutch side and not the gas pedal?
Well, that was my best guess, lol. Hope you can figure out what the problem is. I had a similar thing that happened with my first car, an '86 Cutlass. It was as if the heat was always on, even in the summer. The faster i drove, the more powerful the air coming in thru the lower vents was. I didn't care though, since it was my first car, bought it in '96 for $1K, and was only keeping it till i saved up for something nicer and newer. Annoying as hell though to drive in 90 degree heat, windows down, and hot air blowing across your feet the whole time.
--I'm gonna say it's either something from your engine mod, your air/cooling/heating system, or some other hole in your firewall. re: the heat coming up from your shifter/e-brake: --when you did the conversion...you might not have aheat shield b/t your catalitic converter and the bottom side of your car. This is directly under where your clutch now sits and also your e-brake. This could be causeing "excessive" heat through these two points. --Normally you will get some heat coming up from this area and this is normal. I've got heat coming up through my e-brake but it's not "excessive" heat...just normal (i guess) driving heat... Check under your car for that heat shield and check for any holes in your firewall... p.s. When your air went out...did you start feeling this heat?
i started feeling the heat when i did the auto to manual swap along with the engine...
