Go Back   Automotive Forums Car Chat > Other Cars
Old 01-18-2011, 08:11 PM
iNVisionPROTOTYPES's Avatar
iNVisionPROTOTYPES iNVisionPROTOTYPES is offline
Hand-Crafted 500+HP Mid-Engine Dream Car
Ever wonder what goes into building a vehicle starting entirely from … nothing? Where do you start? What tools do you need?
To answer these questions, we invite you to check out our iNVision Prototypes facebook page! Once there, you'll discover how a vehicle goes from sketches to a full size scale drawings used to build a buck ... to finally fabricating the actual vehicle. You'll see how you can apply this process to any vehicle design your imagination can dream up.
Like us to participate in discussions, ask Nick about your vehicle design, customization and fabrication questions as well as get a bird's eye view of your newest 500+HP mid engine sports car we call R2 built from scratch.
R2's Design Overview
We don't build 'kit cars' ... and set the bar high when building custom vehicles. When everything is said and done, R2 will look as though it rolled off a factory production line. Since it's being built as a driver, the body will be crafted from sheet metal for a quality fit and finish that
leaves plastic, fiberglass, and carbon fiber constructed panels in the dust. You may be thinking "...what about the added weight of an all steel body?" Well, with approximately 6lbs/HP power to weight ratio the final weight will come in around 2800lbs. Not too bad for an all steel car!
Here are a few additional details:
'Like' iNVision Prototypes' on Facebook
Cheers!
A journey in design and fabrication begins with a vision, a single pen stroke ... and in some cases the blow of a hammer.
LIKE iNVision Prototypes on Facebook
Follow us on Twitter
Web: www.invisionprototypes.com
Old 05-27-2011, 08:30 PM
Re: Hand-Crafted 500+HP Mid-Engine Dream Car
Well, it's been a few extremely busy months...but we've been making some excellent progress with R2.
Thanks for all the great emails...we really appreciate your comments and enjoy answering your questions about R2's build progress.
Here are some photos of the build.
The wire frame buck is starting to take shape based on the 2D profile views created.
Passenger side butterfly door roughed in and opened using a single hinge pivot.
This english wheel is one impressive tool! Creating part of the rear 1/4's. The reversed curve fender flair is in, but we've lost some curvature in the horizontal plane...so a few more passes in the wheel to bring it back in.
Fitting the 1/4 to the buck.
Anyway, this was just a small taste of where things are. We've got over 200 other photos posted on Facebook for you to check out when you get a moment. Look forward to seeing you!
Like iNVision Prototypes' on Facebook
Cheers!
Old 08-22-2011, 06:53 AM
Welcome to the hood!
And with the roof topping off the build ... R2 is well underway. Now it's time to fit, weld and assemble the 68 panels.
Click iNVision Prototypes' R2 Build on Facebook for more!
Thanks for looking.
Cheers!
Old 02-24-2012, 03:04 PM
As R2's body shell is coming together we are turning our attention to creating the plugs for the interior molds. Composite panels will then be taken from these molds.
The interior starts as a blank canvas with the medium changing from forming sheet metal to shaping foam. The process will involve creating a basis(plugs) for molds from foam, bondo and clay. It’s gonna be fun!
The floor pans have been pulled to gain access from the underside once the door shells are on.
We're having a lot of fun. Here's a sneak peak of the driver's side interior foam taking shape.
Click iNVision Prototypes' R2 Build on Facebook to see more!
Thanks for looking!
Old 05-17-2012, 10:57 AM
With a hand-crafted vehicle every single piece ... even the things no one sees ...is created by hand.
Here's a small insight into the rear hatch - A few sketches are created, followed by pressed paper templates and finally the metal forming itself...
After pieces are formed, overlapped and screwed together the section is installed for a trial fit.
Overlapped areas are trimmed away, sections butted together and welded.
A little hammer dollie work is necessary to clean up the welded areas.
...and finally finishing it off.
When you get a chance visit and follow us on our Facebook site.
Click
iNVision Prototypes' R2 Build on Facebook for more !
Cheers!
Old 03-05-2013, 09:21 AM
We're on the final stage with respect to assembling R2's body structure!
Once all the panels were created and buck was removed ... final assembly began followed by primering the structure.
For more photos we invite you to check out us our iNVision Prototypes facebook page.
Cheers!
Old 06-06-2013, 10:36 AM
Rexcon Rexcon is offline
Your work has out standing quality measures, car design, body workout and other working pattern are too good.
Is there any other sources for getting up to date from your new working pattern?
I'm much busy from working activities...
used forklifts for sale
Do you like my scratch-built, tube-frame, mid-engine sports car sgraber Kit Cars 13 11-13-2009 10:20 PM
MTM RS6 725 HP vs Lamborghini Gallardo EGear 500 HP batman281 Car Videos 0 05-14-2009 01:39 AM
Digital GFX+Hand craft ART F40 (must watch) peter i 288 GTO | F40 | F50 | Enzo 0 05-22-2005 02:40 PM
dream car Version *2 the dream garage Monkey-Magic-S15-R Initial D 53 03-29-2003 08:37 PM
500 HP motor and Sub-Frame Connectors bcsintegra Camaro Discussions 2 10-28-2002 12:01 AM
Tags
fabrication , metal , mid-engine , sportscar
