Old 07-23-2003, 10:23 AM
snipez's Avatar
snipez snipez is offline
Rubbing Sound From Drivers Front Wheel
Hi
What could be causing a rubbing sound from the drivers side? It seems to get worse when I turn right. Someone told me it may be a caliper, whatever that is. I have pinpointed the sound to behind the front wheel. There is new brakes, pads, etc. It even makes it when I go straight.
Old 07-23-2003, 12:20 PM
buymeabmwm3 buymeabmwm3 is offline
Wheel could be rubbing against the inside of teh wheel well. A quick look at your wheel, while someone turns the steering wheel from lock to lock, should show whether this is the problem. It could be that your brake calipers are too tight, or you have a warped brake rotor. Both of these would require you taking your car into a Meinekie or Jiffy Lube to get the brakes checked out.
1992 BMW 325i conv.
FOR SALE!!
IM me for more info. $6300 /obo
2005 Ducati Monster 620 i.e.
2005 Toyota Tacoma V6 4x4 Double Cab, TRD Off-Road - FINALLY HERE!
Horsepower is 100 ewoks poking you with pointy sticks.
Torque is one wookie pulling your arms out of their sockets.
Old 07-23-2003, 12:36 PM
pcv pcv is offline
Get it checked out. Make sure all the brake hardware are in place. If the brakes are okay, it could be the wheelbearings making a noise. To me it sounds like the right side. You said it gets worse when you turn right, makes me think it is the right bearing. Good Luck.
NOTHING LIKE AN OLD CAR.
Old 10-09-2003, 09:28 AM
omegatoo omegatoo is offline
Re: Rubbing Sound From Drivers Front Wheel
Originally Posted by snipez
Hi
My 96 GT1 is doing the same thing, only it is worse on the drivers side and when turning left. Also with accelerating and certain bumps. I just had my bearings redone, and the brakes, too, so I don't think it is either of those. I haven't had a chance to take the wheel off yet, but I was able to see a broken-down bushing (I guess) on the drivers side that is leaking grease. It is a rubber seal above an angle joint just inside the wheel, visible from under the car. I found it when I was just feeling around for something loose and came back with a handful of grease. I checked the passenger side, and the same seal is intact there.
I now have to track down exactly what part that is so I can get it replaced to see if it fixes the problem. It looks fairly minor, so hopefully it is the cause of the problem and not a result of something worse causing stress on that particular joint. I've taken it in to be checked, but I haven't been impressed with the results from the professionals. Unfortunately, my previously reliable Pontiac dealer seems to have changed personalities and I don't trust them anymore, either, so I guess I'm on my own.
Let me know if you find out anything, and I'll do the same.
O2
Old 10-09-2003, 02:07 PM
snipez's Avatar
yea, you know what it was???/
the stoopid wheel cover makin the sound
07' silverado Metal on Metal intermitent Screeching from Right front wheel well rescue24 Silverado 5 05-20-2010 08:44 AM
noise from drivers front wheel andyrobinson26 Scénic/Scénic RX4 1 02-25-2008 03:49 AM
Pulsing Sound Coming from what sounds like driver front bigdanlan Alero 2 06-26-2006 09:19 PM
Rubbing sound when turning steering wheel markymark30309 Grand AM 2 02-15-2006 07:40 AM
