Old 07-22-2003, 10:40 PM
civic91dx civic91dx is offline
Send a message via AIM to civic91dx
breaks squikin
well everytime i brake my break squeak really loud it is only on the driver side. i have just put new brakes on it about a month ago. i looks at the break and they all look good. i need to get it fix by 2morrow someone is comin to look at my car. thanks guys
91 civic sold, i miss it
new car 98 Monte Carlo Z34, dont worry guys i still love honda
http://www.cardomain.com/id/losboricua
Old 07-22-2003, 10:44 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
sometimes with new pads, they like 2 squeel after a bit, goto ur local parts store and by disc brake anti squeel....
either that, or ur braking wayyyy 2 hard
Old 07-22-2003, 10:45 PM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
What did you do to the brakes? Squeaking can be caused by many things. The main cause is pad movement. If you used a cheap pad they may not fit properly and that will cause noise. You may be able to correct the problem by shimming the pads. Also if the rotors were not resurfaced, that can lead to noise. Or you can just slap a set of organic pads on it they do not make noise at all.
Old 07-22-2003, 10:57 PM
well the noise happens when i break slowly at slow speeds too. i bought new rotors at the same time. the pads are semi- metalics. i thinks the outter pad was a lil bit lose i will try shim it.
Old 07-23-2003, 12:12 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
The semi-metallic pads will make noise some times. They have small metal particles in pad along with other materials. When the pads wear to the point that a few of those metal particles rub against the rotor you get the metal on metal squeal. Thats why i use the cheapest pads i can get, they're nice and quiet.
engine break-in thunderbirdcoupe89 Thunderbird 2 12-10-2009 01:22 AM
break light and break light chime nick4244 LeSabre 2 06-28-2007 06:22 PM
When things break, they fuckin break..... l_eclipse_l Off-Topic 15 07-06-2005 07:29 PM
Shudder when breaking at high speeds / pulsating breaking jessb45 Aurora 17 09-28-2004 09:01 AM
Break Problems, ABS and Break Light Soundwave_ General Discussions 1 01-31-2004 06:47 PM
