Old 06-28-2007, 08:51 AM
nick4244 nick4244 is offline
break light and break light chime
Whenever I put the 1995 buick lesabre in gear and accelerate the break light and the chime go off. It will continue until I tap the break. Lately it has stayed on constantly. How do I fix this?
Old 06-28-2007, 09:28 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: break light and break light chime
Wrong forum
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 06-28-2007, 06:22 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Wink Re: break light and break light chime
You can start by checking the brake fluid level in the reservoir. If it is low, the chime will sound and the light will come on. Now, if it is low, there is a reason. It could be a leak somewhere, or it could be your pads are worn down enough that the calipers are holding all the brake fluid. Do not just add fluid, without checking the cause of the low level condition.
