Old 07-22-2003, 01:18 AM
97civichx's Avatar
97civichx 97civichx is offline
Send a message via ICQ to 97civichx Send a message via AIM to 97civichx
annoying squeeling noise
for a while now my car has been making this annoying squeeling noise and i have no idea what it is...i was thinking it might be a loose belt but the belts feel fine. it doesnt really affect performance, its just annoying and it only happens at low rpms like when idling or in 1st gear. just thought you guys might have a clue?
97 civic hx
mod list: CAI, 17" wheels but now removed and much more to come.
not much of a list yet really
Old 07-22-2003, 11:17 AM
97civichx's Avatar
does anyone know or is this just a dumb question? my brother thinks that the alternator might be going bad but i dont always trust his judgement.
97 civic hx
Old 07-22-2003, 11:31 AM
-Go_Hawks!- -Go_Hawks!- is offline
My roommate had that problem with his Talon, a lot of time it was just a glaze on the belts, causing them not to get good traction. He got some kind of spray to put on them and it helped a little.
Old 07-22-2003, 12:25 PM
97civichx's Avatar
do you know the name of the spray or what kind it was?
97 civic hx
Old 07-22-2003, 04:36 PM
candlaudio candlaudio is offline
Send a message via Yahoo to candlaudio
you could also spray your idler pulley with some wd-40 and see if that helps, and you can spray that on the belts also, i have done that before and it helps.... try those things...
94 honda civic dx
d154b7
pacesetter header
btm stage 2 clutch
c.a.i
short throw shifter
altezza's
gauges and bezel
interior painted
dropzone coilovers with 2" drop
205/40/16 yokahama parada's
99 honda civic ex vtec
dc header
c.a.i
dual tip muffler
Old 07-22-2003, 11:45 PM
MaxGCivic MaxGCivic is offline
Send a message via ICQ to MaxGCivic Send a message via AIM to MaxGCivic
my car will squeel like a sonovabitch if I go threw a puddle and get some water on the belt....but that's probably somewhat normal.
Old 07-22-2003, 11:52 PM
HXCivic97 HXCivic97 is offline
Send a message via AIM to HXCivic97
yeah its just a slipping belt. Which one you'll have to discover for yourself, but if it does it when the car is idling, i'd say chances are it's the alternator belt. All those fixes above should work - take your pick.
When was the last time you had your belts changed by the way?
Old 07-23-2003, 03:54 AM
97civichx's Avatar
well i bought the car in mid april from a dealer and i havent changed any belts or anything. the only thing i've done is had a normal oil change. everything seemed to be running fine. i'll try to spray the belts. would putting a little lubricating oil on it be about the same or is that a bad idea.
97 civic hx
Old 08-11-2003, 11:12 AM
holyniht holyniht is offline
My 94 civic does the same aswell, but it only started doing it after i cleaned the engine up ( it needed it), it squeeks during idles sometimes but usually goes away after i rev it a few times. my cousin said i should use something called wax chaulk. Just want to confirm it b4, i go out and spend some $$$. and also my power steering pulley is wobbles a lil bit, any where i can get a new one without having to shell out a $150. Thanx in advance
Old 08-11-2003, 12:32 PM
97civichx's Avatar
look on the internet on ebay
97 civic hx
Old 08-11-2003, 12:39 PM
thanx for the info, found a aem tru-power pulley kit, for a decent price. what about the wax chaulk, would that stop the squeeling?
Squeeling noise...really annoying bh04 Cavalier 2 05-23-2005 11:32 PM
loud squeeling noise - not belt SlickSL2 SC/SL/SW 6 01-04-2005 12:57 PM
wierd squeeling noise 00tegra Integra 1 12-15-2003 07:48 PM
squeeling noise aficio400 Engine 3 08-17-2002 09:55 PM
odd squeeling noise when when turning -=Evol90Accord=- Accord/TSX/Accord Hybrid 3 01-29-2002 09:47 PM
