Old 07-20-2003, 02:57 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
coolant everywhere
I was driving the other day and my temperature gauge has never gone above the middle before but that day it was just a little above. I kept driving and all the sudden it skyrocketted. I got home and there was no coolant at all left. I filled it up and drove good for another week. Then it happened again. Now it happens every few days. When I park the car, coolant immediately starts leaking, steady drops if not a drizzle. Its coming from a strange spot though, right underneath the alternator. I cant get a good enough look at it so I was wondering if anyone knew where it might be coming from. I just need the car to run for another week or so, so im not too worried about it, but I would like for it to be in good enough condition to sell.
Old 07-20-2003, 02:58 PM
GTA's Avatar
GTA GTA is offline
Whee..
water pump is right near where the alternator is. so im guessing the water pump is dead.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 07-20-2003, 03:04 PM
that would cause coolant to go everywhere?
Old 07-20-2003, 03:12 PM
will a water pump from a 1.6 fit my 1.5? Cuz i have an Si engine just sitting in my garage with under 100k miles on it
Old 07-20-2003, 04:15 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
yeah itll fit, but you are better off just buying a water pump. its not that costly considering you will get a lot more mileage outta it than that one in the other motor.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 07-20-2003, 04:21 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
I actually try to change my water pump every 100k miles or so.
Honda Enthusiast
Old 07-20-2003, 04:22 PM
yea, i would if I was keeping the car, but my ZC hatch will be up and running in a few days and im gonna stop driving this one.
Old 07-20-2003, 06:14 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
I drove for a long time without a functioning water pump, or coolant for that matter. Although I limited my drives to 10min. It'll run strong for quite awhile, trust me.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 07-20-2003, 07:04 PM
I work almost 30 mins away though
Old 07-20-2003, 09:11 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
It might not be the pump. The coolant pipe on the back of the block runs right there as well. I had to change mine because a small scratch had rusted over the years to form a hole. Jack it up to see if you can't get a better view. If that black pipe right under the intake manifold is wet, or discolored, thats your problem and they are a major pain in the ass to change, due to the slight U shaped bend in the middle and the lack of room.
Brown sludgy coolant (oil in coolant?) wagslick Malibu 3 01-03-2010 08:29 PM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
LEAKING ENGINE COOLANT everywhere except radiator JBeamen 7 Series 5 10-23-2005 08:20 AM
Coolant EVERYWHERE azn3000GTRacer 3000GT/Stealth 3 06-27-2005 02:35 AM
