Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 09-19-2005, 09:59 AM
JBeamen JBeamen is offline
LEAKING ENGINE COOLANT everywhere except radiator
my check coolant light came on, it was low refilled. drove about a 1/2 mile noticed a lot of smoke in my rear veiw mirror, coolant light came back on. pulled over to check again. smoke everywhere, noticed a puddle forming on passenger side aft of front tires. no visible leaks around the radiator. does anyone have any ideas?
Old 09-29-2005, 09:23 PM
Boinggg Boinggg is offline
Re: LEAKING ENGINE COOLANT everywhere except radiator
I have a couple things you can look at.First check to see if you may have a hose by the firewall that is cracked happened to me.Also you may look to see if the auxiliary water pump buy the firewall is leaking,also a possibility.Good luck.......
Old 09-29-2005, 09:25 PM
One more thing BMW reserve tanks are natorious for splittingalso happened to me...........Good luck......
Old 10-02-2005, 09:42 AM
91HO305TPI 91HO305TPI is offline
check rear heater hoses behind engine cover to see if split or blown, coolant tanks ar also notoruous for craking on back side where you cant see it.aux water pump is on drivers side and mostlikly not problem.
Old 10-23-2005, 07:21 AM
Bear Bear is offline
Coolant Leaks
I have had them all. Check the "Y" shaped hose off of the Coolant Expansion Tank(reservoir) and also the plastic piece that that hose attaches to on the tank (best bet is to evacuate the tank and remove it). Check the crossover line bneath the exoansion tank and the heater lins off of the auxillary heater valve (pop cover on the valve to get a better look). I had a leak at base of expansion tank where rubber hose comes off and it was a crack in the tank where hose attaches, I discovered a metal sleeve 9in the tank at that point and the crack allowed the sleeve to slip toward the hose. I tapped the sleeve back up the plasric neck and retightened her and that took care of that leak.
Old 10-23-2005, 08:20 AM
Coolant Leaks
Here is a website for all BMW owners, it is Don Gale's and has many good repair procedures (n text and photo). Specifically for you some jpeg drwings of the coolant hoses. Go To:
www.nmia.com/~dgnrg/Page_2.htm
