Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 07-20-2003, 12:54 AM
ssxty8 ssxty8 is offline
Question Weird sound at air inlet box
Hello everyone, new to the site. I have several questions for you guys, but I'll start with this one. My car makes a strange "humming sound" which comes from the air inlet box. I know that cause I've opened the box and the sound gets louder, looks like if it were originated at the trottle body/intake area. The sound is not present all the time, it comes and go as I drive the car or at idle. My car is a 92 Grand Marquis LS with the 4.6 lt. engine. Any help in this matter will be greatly appreciated.
Old 10-29-2003, 08:29 AM
jhmoron jhmoron is offline
ssxty8,
It has been awhile since you posted this thread so you may have already solved your problem, but I just joined and it so happens had this repair done on my '93 two days ago. You need to get the Idle Air inlet hose replaced. This hose connects to the airbox tube just before the throttle body. I was quoted $15 from the Ford dealership. My mechanic charged me $25 but he installed for me which I would recommend because the back end of the tube plugs into a connection that is between the firewall and the back of the motor. Hope this helps.
Old 10-30-2003, 04:30 AM
Thanks for the reply, in my case, the damaged part was the IAC valve. Replaced myself and problem solved. Thanks again...
Old 11-03-2003, 12:00 AM
XBAJBUSX XBAJBUSX is offline
i think i have the same problem where is it and how much it cost did make noise when you ideal and when you accelarate the noise went away let me know thanx
Old 11-03-2003, 02:35 PM
In my 92 GMqs, it's located on top of the engine, at the back area of the intake manifold, behind the throtle body ass'y. Kinda tricky to get to it, but can be done at home. Just don't try to unplug it before removing it and be careful while removing the 2 screws, you may loose them. A new motorcraft cost me $30.
Old 11-03-2003, 05:45 PM
yeh i just fix it today it was the vaccum hose inside under the steering column .. it got tangle up when i made a turn and it got disconected
thanx
98 Cav Rad Inlet Pipe MrCheapGuy Cavalier Problem Diagnosis 2 04-20-2010 07:50 PM
What's that box BEFORE the air filter box? Shrewz92 Let's get Technical! 5 09-02-2009 06:30 PM
where do i find the air inlet cotrol unit scewydog3 Clio/Clio II/Clio III 0 10-29-2008 11:12 AM
Weird sound when depressing the throttle skifaster 911 2 07-10-2003 07:58 AM
Weird Sound Commin From Rear Right Wheel Cav '71-'87 Civic | CRX 2 04-24-2002 10:07 AM
