Old 07-18-2003, 02:43 PM
goskyline2003 goskyline2003 is offline
Talking Could you ?
I was planning on swapping a H22 in a 93 Honda civic HB.
But some people say the engine is too heavy for the front
Suspension. Do you think it is possible to drop a Prelude
Suspension in the front so it could take the weight of the
Engine.
Old 07-18-2003, 04:38 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
It's not the weight that's the problem. It's the weight distribution. The Civic chassis was not designed for the way the H22 is mounted. The H22 isn't much heavier than a B series. The suspension won't help.
Old 07-21-2003, 01:53 PM
spdbtr79460 spdbtr79460 is offline
I your only going in a straight line then your alright. But if you wanna take a corner fast watch out
Old 07-22-2003, 07:14 PM
TuRboVrOoM TuRboVrOoM is offline
b16ej1 is EXACTELY RIGHT
Old 07-23-2003, 07:54 AM
89B18C1CRX 89B18C1CRX is offline
Send a message via AIM to 89B18C1CRX Send a message via Yahoo to 89B18C1CRX
Not true ive seen many of hatchbacks with the h22 in my town. It just a matter of building it right. The motor bearly fits in the bay is defidently a tight squeeze. And as for the suspension you jus tneed to build it strong before you put the motor in. By building im saying you need springs shockc struts struct bars, all that so you can keep the motor from swaying your car when your whiping around those courtry roads at 100 mph heheheh. It will defidently fit and work you just need to make sure all is tight and secure and strong before you go out cruizin.
Lets line um up biatch!
could you shop a sportage patate Graphic Manipulation 6 03-11-2002 04:15 PM
Could you be a stay at home Dad or trophy husband? Sham365 COMPLETELY off-topic 14 02-12-2002 04:44 PM
Could you be a hitman? -cy- Philosophizing 32 01-21-2002 12:10 PM
How could you not have a forum for the 2CV? enginerd General Discussion 1 10-02-2001 03:49 AM
