Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-18-2003, 07:51 AM
civic4wd civic4wd is offline
add gas with turbo
i search a cheap way to add more gas
i begin a project and i need help
i have now
88 civic wagon 4wd
d16y8 stock si intake
srp forged piston 9.0 comp
gready turbo kit + cooler 10 or 15 psi daily driven
i want to know, some thing about fuel upgrade.
actualy have stock injector and fuel pump
what kind of injector i need. dsm or prelude?
i can have 98 sir fuel pump it is ok? or is the same like my 88 si?
thanks to all!!!!!
civic4wd
www.geocities.com/civic4wd
Old 07-18-2003, 08:22 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
get a 255lb fuel pump a fuel pressure regulator some 450cc+ injectors and a s-afc or some sort of air fuel controller to set it all and you shoud be fine..
1
Shift_BOOST
97 s14
Old 07-18-2003, 04:49 PM
civicgsr_T4_60-1 civicgsr_T4_60-1 is offline
Send a message via AIM to civicgsr_T4_60-1
1
Do not do the afc, hack. And if your gonna tell someone that's all they need, you gotta give some detail. Everyone doesn't know about the hack or how to hook it up and what settings to use. If anything, afc, 440cc injectors, 255lph intank pump, and a 12:1 fmu. that is all you'll need. If you really want to step up, the hondata S200 is a great unit.
00 civic with bolt-ons, i swear
Old 07-18-2003, 06:35 PM
PWMAN's Avatar
PWMAN PWMAN is offline
Old 07-19-2003, 04:34 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
any pics of your ride sounds sweet
Old 07-20-2003, 03:02 PM
funkdaflex1 funkdaflex1 is offline
wouldnt type R injectors be more than sufficient??
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
Old 07-23-2003, 04:44 PM
i don't know what size they come, but I know you need to run some decent fuel and stock injectors can only handle a minimal amount of boost.
Old 07-23-2003, 06:19 PM
SleeperCivic SleeperCivic is offline
An FMU would be a quick fix for you, but I would DEFINIETLY consider changing the fuel componets (injectors and pump) out before increasing boost. You never know when one of these are going to give out and make you detonate. The age of your car doesn't help, either! I guess if you replace them with new ones, age doesn't matter.
'04 SRT4 [Black] - 13.46 @ 102.9 (2.09 60') - R.I.P. 1999 Civic EX Turbo
.:ATP Up Pipe .:HKS SSQ w/Purple Insert .:K&N Typhoon CAI
.:Greddy Full Auto TT .:Greddy Profec B Spec II EBC .:Greddy Catch Can
.:AGP Billet Wastegate
.:Stock Ass-whoopin Installed
Dyno Proven - 234.6whp / 250.9tq 13.66 Video
Old 08-02-2003, 09:05 AM
Talking
tanks you all for your help
i need good 255lph fuel pump and big injector more than 400 and i for hondata s200
i customize my own ecu with ecu controle.
i use pm6 ecu with rpm vtec switch
only one think i dont understand is:
12:1 fmu??????????
Rick
88 Civic 4wd
98 d16y8 Turbo
no spin just grip!!!!!
in construction at
civic 4wd
Old 08-02-2003, 11:05 AM
You're running a high amount of boot, using a programmable ECU, and plan on getting larger injectors. You shouldn't need a FMU.
Old 08-04-2003, 02:21 PM
thank you sleeper!
how many psi you set your fuel regulator
rick 4wd
civic 4wd
Old 08-04-2003, 05:15 PM
I don't set it, I use the stock FPR.
Overheating after filling with gas dupson Dakota 1 02-25-2009 05:40 PM
how much gas do turbos burn? ikou Forced Induction 17 04-21-2004 01:15 PM
4G63 turbo motor with turbo for sale soyee7 Off-Topic 7 12-09-2003 07:04 PM
LS with turbo, or LS with LS/VTEC and Turbo IntegRocket32 Integra 3 10-11-2002 01:13 AM
Anyone with pix of a VR6 with turbo installed? XaznPKdogX Jetta/Vento/Bora 5 07-12-2002 11:56 PM
