Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-14-2004, 04:23 PM
ikou ikou is offline
Send a message via AIM to ikou
how much gas do turbos burn?
hey,
i was wondering how much more gas a turbo would burn on a 2000 civic si, than the car usually burns. does anybody know? thanks.
Lance
Old 04-14-2004, 04:54 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
Re: how much gas do turbos burn?
the turbo itself doesnt burn any fuel...its the upgraded fuel system to support the turbo that burns more fuel. the ammount of fuel youll burn would depend on the size of the turbo and the ammount of boost you would be pushing...therfore the more fuel you would have to supply for a proper mix.
Old 04-15-2004, 01:52 PM
93hybridaccord 93hybridaccord is offline
You will notice a change in fuel mileage, but it's not gonna be a huge jump especially if you are just going to be pushing like 8psi. Just make sure you tune it. If you just throw a kit on you'll be running rich. Tune it and lean it out and it will save gas.
93 accord - jdm h22a
2003 srt-4 - daily driver
Old 04-15-2004, 02:39 PM
Reed Reed is offline
Send a message via AIM to Reed
if you are using the turbo for making your car faster then you shouldn't care about mileage that much, you can probably afford a couple extra dollars a week.
you can also use a turbo for saving gas as you can tune it to run the same amount of fuel but with more air, thus giving you more power per unit of fuel and getting you further per tank.
Old 04-15-2004, 03:50 PM
XixGenuinexiX XixGenuinexiX is offline
i wouldn't advise doing what Reed just said. That's a good way to blow an engine. When tuning under boost always try to keep an 12:5 AF ratio or lower for added safety
Old 04-15-2004, 05:12 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Re: how much gas do turbos burn?
This is called running lean (too much air, not enough fuel) and it can cause your pistons to melt. Running lean causes heat that no cooling system will advert.
Like most people have said, the turbo itself does not use more fuel. You add a turbo and you're adding airflow, which means you have to add more fuel. As long as you aren't mashing the throttle everywhere you go you shouldn't see much of a difference.
Old 04-15-2004, 09:20 PM
Reed, who gave this this idea. N/A motors naturally run leaner than FI motors.
I've seen a/f ratios on N/A motors as high as 14:1, if you tried to do that with an FI motor, you've have a molten mass of pistons. Whenever you add air, you have to add fuel.
Old 04-16-2004, 03:36 PM
boosted331 boosted331 is offline
Re: Re: Re: how much gas do turbos burn?
If you're running a turbo with a good EMS system, your gas mileage should not waver much/at all if you keep your foot out of it. If you get on it, be prepared to suck back a ton of fuel.
Old 04-18-2004, 02:34 PM
jajimo's Avatar
jajimo jajimo is offline
Not true, if you were to replace your stock cooling system with one which drops the entire engine compartment into a bath of 1.9K superfluid helium, you could run as high of compression as your engine could stand, and if you wanted to go higher, just increase the pressure of the bath to equilize it. Of course, this means your car couldn't, you know move.
Old 04-19-2004, 12:13 PM
I'm not saying the guy should run like 10 psi, after all it is a honda engine probably without engine mods. he could safely run 4 or 5 psi and lean it out a little, hell if he knocks back the timing and intercools he could probably run more.
Old 04-20-2004, 06:06 AM
YellowITR479 YellowITR479 is offline
I dunno, I get about 90 miles out of a full tank in my GSR and im only running 440 cc injectors and a fuel pump
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 04-20-2004, 01:26 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Reed, you make no sense!!! COMMON SENSE ALERT:
Fuel contains the energy used to create horsepower. If you add less fuel, you will create less power.
Not so common sense, but should be to anyone who knows anything about cars - leaning an engine out is about THE WORST thing you can do for your engine... In fact, short of chucking bolts into your intake while the engine is running(or anytime for that matter), I really cant think of anything worse. A precise A/F ratio is THE KEY TO POWER AND PROLONGING ENGINE LIFE!!! You will make the most power with the perfect A/F ratio. Running lean will produce a bunch of excess heat, which not only endangers your pistons, valves, cylinder walls, head, turbo, and pistons, but it makes everything inside your engine considerably hotter which will heat the intake charge on the intake stroke and therefore give you a less dense mixture and less power! Hooray! Running rich causes fuel to deatomize and turn back to liquid, so there is less combustable fuel in the chamber, as well as making it harder for the spark plugs to fire. However, running rich aint all that bad - it wont cause any damage; your engine might not run as smooth and you'll waste gas, but at least you're not in danger of going lean.
Old 04-20-2004, 02:46 PM
Not True.
naturally aspirated engines normally dont run at stoichiometric mixture if you put more air into the cylinder without increasing the amount of fuel you will run at 14.7 or maybe higher and since that will increase the heat in the cylinder ( and burn all of the fuel and air at 14.7:1 ) you will get more power out the the same amount of fuel, thus reducing the amount of fuel it takes to make a specified amount of energy. sure you may run hotter, but not that much ( im not saying that anyone should try to run 10-20 psi on stock internals or stock fuel ). also, a little added heat is nothing that a slightly upgraded cooling system couldnt dissipate. and like i said, intercooling and retarded timing will take care of knock, detonation, or preignition.
by the way XixGenuinexiX , what the hell is a 12:5 A/F ratio
Old 04-20-2004, 05:50 PM
Polygon's Avatar
The Red Baron
Re: Re: Re: Re: how much gas do turbos burn?
That's a good one, I'll have to remember that.
Old 04-20-2004, 11:14 PM
duplox's Avatar
I'm sorry, but I can't condone running lean at all. Lean is bad. Don't do it. Even if you run 'just a little bit lean', if your wastegate gets stuck for a second and your boost spikes over what your fuel is capable of, or if your fuel pressure drops for a moment, you'll go very lean and burn your engine. With a properly tuned and built engine, you will waste very little gas at stoic and definately will not be worth running a bit lean. You might get an extra mile on a tank of gas.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
