Old 07-12-2003, 03:46 PM
PurdueTA1986 PurdueTA1986 is offline
Idle Problem in 305 TPI
I have a 1986 Trans Am with the 305 TPI that seems to have a problem where it won't idle at all. When I start it, the engine fires, but will just die, and not even try to run. If I open up the throttle when I start it, it runs normally, until I let off, and again, it just quits, like I turned the key off. Any ideas? At first I thought it possibly could be a mass air flow sensor issue, but then I figured if it was an issue with that, it would probably try to idle. Any help is greatly appreciated.
Old 08-23-2003, 07:47 PM
daman daman is offline
Yes do some trouble shooting on ether the mas or the tps(voltage should be eather .54 or a littel higher on the tps for better thottle responce)
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 02:59 PM
1987 Grand Marquis 5.0L FAST IDLE problem Johnobub Grand Marquis 3 10-09-2009 08:10 AM
Idling Problem williamjbronski Cavalier Problem Diagnosis 2 08-10-2009 10:39 AM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 07:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 11:27 AM
