Old 07-11-2003, 12:26 PM
black98gtp black98gtp is offline
Temp reading -38 degrees in 90 + weather!
I posted a little while back about the Auto climate control going nuts on my 98 Grand Prix GTP. Unfortunately I did not get any response. I hope someone can help, I am going to a repair shop next week.
The outside temp reading is stuck at 50 degrees even in this 90+ degree weather. Everytime it rains the outside temp reading drops in a matter of seconds to -39 degrees and will only blow very hot air out of the vents, eventhough I have it set to 60 degrees AC on high. This causes dangerous driving conditions to say the least. It used to only happen in very heavy rain, now if it is humid out or sprinkling the same thing happens.
Anyway I have an appointment to have my car looked at next week and being that I am a woman I get treated like I know nothing about cars... Since, in this case, I actually do not know anything about what the exact problem is I do not want to be taken to the cleaners. Has anyone had this trouble? If so, what needed to be repaired so that I do not go into this blind and about how much did it cost?
I have enjoyed the helpful information on this forum. You all are a wealth of information.
Thank you!
Christine
Old 07-11-2003, 08:24 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Temp Sensor
Christine,
Hope you read this before you take car in. It sounds like the Ambient (sp) Air Temp sensor has gone bad.
Open the hood of your car, look between the front bumper and radiator. On the left side (you facing car) you should see a sensor. First make sure it's plugged in, if not go to your local dealership and ask for a new sensor. I think that it cost around $8 bucks.
I accidently broke my sensor when I was messing around with a resistor mod. Replace sensor, and at first didnt seem to fix it but after a few driving cycles it was fixed.
Hope this helps
Tim
Old 07-11-2003, 11:21 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
After replacing the sensor you need to drive the car for roughly 10 miles to recalibrate the sensor.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 07-12-2003, 05:00 PM
gjimerson gjimerson is offline
Angry 35 degrees during 90+ days
I have a White 2000 GTP and recently began experiencing this problem. I am not sure what it is but I suspect it has something to do with the ambient temperature sensor. When it's around 90 degrees or hotter, the temp reading begans to decrease and stays at 38 degrees untile the outside temp decreases. Please provide any information you might have.
gjimmy
Old 07-12-2003, 05:59 PM
Your advice worked!
Thanks tons!
I just got back from driving my car around, and I am happy to report it is reading an accurate 91 degrees. I bet when the car was repaired after my car accident they did not reconnect the sensor. I found the connection just hanging there.
I plugged it in, turned on the car and the temp began to rise. It is the first time in awhile my auto air has worked correctly!
You all are great and saved me some cash!
Christine
Old 07-12-2003, 06:57 PM
Ripn12s's Avatar
Glad everything worked out.
Old 05-09-2004, 07:13 PM
grandprixgt300 grandprixgt300 is offline
Send a message via AIM to grandprixgt300
does anyone have a picture of exactly where this sensor is, i am having the same problem but i can't find it...thanks in advance
Old 05-09-2004, 07:30 PM
Ripn12s's Avatar
Re: Temp reading -38 degrees in 90 + weather!
what year gp do u have
Old 05-09-2004, 07:43 PM
Ripn12s's Avatar
if you have 99-03 then your going to have to remove the plastic by the hood latch to see it. Or you could get under the car and look infront of the radiator on the pass. side.
Old 05-09-2004, 07:46 PM
yea i have a 99, so that explains it...thanx for the input
Old 05-10-2004, 02:20 AM
GTPgirl's Avatar
GTPgirl GTPgirl is offline
Send a message via ICQ to GTPgirl Send a message via AIM to GTPgirl Send a message via Yahoo to GTPgirl
In a 99+, it's easier to see and get to from underneath, I had this problem, had to change my Ambient Air Sensor. Lie down on the passenger side and scoot far enough under that you can see the gap between the front bumper and the radiator and look up. You'll see this little thing stuck to the back of the bumper. That'd be the sensor. takes about 2 minutes to change.
GTPgirl
Black 1998 Camaro - currently driving
Black 1999 Grand Prix GTP - burned March 2008
Plum Crazy 1970 Dodge Challenger - work in progress!
2000 venture stalls when air temp below 38 degrees setlocb Venture 10 01-17-2009 05:05 PM
my a/c is not helping with the 105 degree weather themindbender Cutlass Series 5 06-09-2006 02:34 PM
New problems after the -35 degree weather Lindsay403 General Discussions 3 01-06-2005 01:03 PM
real problem! AC not working in 100 degree weather torch2004 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 07-15-2002 09:28 AM
