Old 07-09-2003, 11:23 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
ZC distributor re-pinning
So I was talking to a performance shop today and they said that on a ZC swap most people don't know that you have to re-pin the distributor. First of all I don't know what the hell that means, and secondly, why?
Old 07-09-2003, 11:41 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I had to swap out plugs since the ZC one was larger than the other end on my DX harness. I just used the DX distributor plugs plugged into the same exact spots. Worked fine and was easy.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-10-2003, 12:01 AM
Phact's Avatar
Phact Phact is offline
Send a message via AIM to Phact
i asked the guy who did my zc if he repinned it and he said he had to...here it is...
******** (8:12:38 PM): had to
******** (8:13:04 PM): 7 wire vs 5 wire
My WebSite: PhactMusic.com GRAND OPENING!
Other Ride: 91 Honda Civic Hatch DX (Currently not running.)
It just had to dry dawg - DarkImportGrey
Old 07-10-2003, 01:05 AM
SiRWannabe SiRWannabe is offline
If I'm not mistaken, but 2 wires from your dx harness have to be hooked up to your cam sensor by the dizzy, the silver thing thats on the end of the exhaust cam I believe
Old 07-10-2003, 06:33 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
yeah you either have to re pin it or you can do what i did and make an adapter harness so its plug and play, all you do is cut the plug off your old dist. (or one from a junk yard) and cut the plugs off that come in with the new engine, match up the colors and soder...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 07-10-2003, 08:49 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...its alot easier than it sounds..
http://www.geocities.com/civiczc/zcwire.html
SOLD!
Old 07-10-2003, 09:15 AM
Thanks a lot guys!
95 Caprice SW change distributor help (pulley removal) bigwar Caprice 11 02-26-2011 10:19 PM
2002 Distributor Install Procedure wmako M Bodies 2 02-02-2010 09:16 PM
Tamiya is re-re-re-releasing the Porsche 956 in Kenwood colors ScaleCentral Car Modeling 5 04-16-2009 04:59 PM
1995 Blazer 4x4, Re-Install Distributor, Help to set timing pls. TDC, BTDC sneakers98 Problem Diagnosis 3 08-14-2007 08:55 AM
white 99 g20 wih gold pin stripe remove pin or not? cas8_1999 Cosmetics 5 09-17-2001 04:07 AM
