Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 07-07-2003, 12:36 AM
Alan0330 Alan0330 is offline
camber kit for 92 civic with 1.2 inch drop???
i'm going to get either the H&R OE spring or the Koni RSK suspension kit. Which will lower my car ranging from 0.75" to 1.2". Can someone who own a lowered 92 civic tells me whether i need a camber kit or not? I just get a new set of Yoko ES100, and i wish to have them for couple of years. Any input would be greatly appreciated!!!
Old 07-07-2003, 01:32 AM
BullShifter's Avatar
You should only need a camber kit when you go 2" or under. When you have the car aligned after the suspension install you'll find out for sure if you need it. If you plan on racing & want some adjustablity go with the kit
Old 07-07-2003, 02:36 PM
xTEMPLARx xTEMPLARx is offline
Send a message via ICQ to xTEMPLARx Send a message via AIM to xTEMPLARx Send a message via Yahoo to xTEMPLARx
Would you say the same idea applies to Accords? I have a 2001 Accord 4dr that I am going to be putting 18's on... I don't want to put it in the weeds but I do want to kill the gap. If I can do so without needing a camber kit I'd prefer to do a little less for a little less hassle.
Also, in your experience(s), do hondas tend to need both front and rear camber adjustments when lowered to around 2 inches, or mainly only front end?
Thanks.
T
Old 07-07-2003, 02:50 PM
Stay above the 2" mark & you should be fine
both front & rear kits are needed
Old 07-07-2003, 02:56 PM
Roger that!
Was looking at a 1.75" f x 1.75" r spring setup... So that should be kosher. I suppose the best way to find out will be to install everything and see what the alignment shop says.
Thanks for the input!
Old 07-07-2003, 11:56 PM
17s with 1.5 inch drop? SiRacer Wheels/Tires/Suspension 11 02-27-2005 10:43 PM
FS: Springtech 1.75 inch drop springs and camber kit Pontiacracer99 Grand AM 1 08-22-2004 09:16 PM
camber kit for a 2" fr/drop required?? fyrewyre819 Tires and Wheels 4 02-02-2004 05:02 PM
largest tire with 2 inch drop on a Z28 rnico Camaro Discussions 0 01-16-2003 07:23 PM
3 1/2 inch drop? vik Accord/TSX/Accord Hybrid 10 03-31-2002 09:39 PM
