Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-06-2003, 07:53 PM
hondamikesd hondamikesd is offline
What do I need to turbo and what are my limits?
Well here's the deal, I want to know what I need to run a turbo setup on my 95 del sol si, I've been doing alot of research on the subject and have decided to go with a custom setup (sorry don't have 2.5-3G's just laying around to spend on a kit) anyway I need to know the basics more for A:F tuning and also how much boost I can run safely on stock internals (don't want to run with the big boys, just against my buddies' integs and ludes) Anyway I need to find out which is the best FMU (such as an apexi S-AFC, keeping in my mind I don't want to go with hondata, also I need to know if I need any modification to my MAF?( or MAP? )sensor after installing the right FMU, also need to know what is a good way of ignition retarding. Anyway I guess basicaly I am just looking for what kind of troubles I might run into (inadequate pump flow, fuel injector problems, and so on...) also if anybody has personal experience turboing thier d16z please feel free to share, I'm always open to ideas.
THE WHOLE GOAL IS NOT TO END UP ON THE BLOWN MOTORS SECTION ON [url=http://www.homemadeturbo.com]
if you see my taillights, you're not slow, you need to shift out of neutral
Old 07-11-2003, 07:13 AM
smokey8890's Avatar
smokey8890 smokey8890 is offline
don't try to cut coners when it comes to turbos.
Old 07-11-2003, 10:11 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
5-8 psi max on stock internals 10 psi is pushing it..
yes get a s-afc
you need all the turbo stuff(turbo,exhaust mainfold,i\c piping, b.o.v. fmic..ect.) i would sugets to do your fuel sys. get ahi-flow fuel pump and maybe some 450cc injectors. get new plugs and wires. with a turbo you also need to run a oil line to your turbo that means drill and making connections in your oil pan.. i say go get the kit itz alot easier and less chance of screwing up your car..
good luck
1
Shift_BOOST
97 s14
What to photograph and what to ask when I meet an F1 and/or his Owner?" MAC876 F1 2 03-08-2009 04:06 PM
I have a 1990 celica gt-s, im rebuilding I need suggestions, and what kinda engine? NinjaMechanic Celica 7 08-21-2005 04:21 PM
What turbo and what do i need 91 Eclipse Off-Topic 18 02-14-2005 08:50 PM
Help need turbo and s13 conversion S13wanabe 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 11 10-01-2004 04:37 PM
What new mods and kits are out for the newest accord? Lingerie_Ripper Accord/TSX/Accord Hybrid 4 02-10-2003 09:27 PM
