Old 07-05-2003, 12:41 PM
SupaStealth TT SupaStealth TT is offline
Send a message via AIM to SupaStealth TT
what is an assymetrically turbocharged system?
i was looking on the net one day and somethin' on saabs interested me, an assymetrically turbocharged system. i didn't really get what it means, i think what i got from some of the info is that they basically put a turbo on one bank of cylinders and not the other? Wouldn't that be hard on the engine since one side is pushin' more backpressure than the other? but it would seam like it would almost eliminate turbo lag cause one side can generate normal power and doesn't have to push anything.
Do you think anyone would be stupid enough to put a Turbo on a '99 Ford Taurus SE? You thought wrong!
Old 07-05-2003, 06:01 PM
i would appreciate anyone with any knowledge on the subject, its kinda urgent, i need to know if i can just buy one medium sized turbo rather than two smaller turbos and intercoolers thank ya much
Old 07-05-2003, 07:20 PM
Warpspeed Warpspeed is offline
Asymmetrical turbocharging is where a single turbo only is mounted on one bank of a V engine (Saab V6), and the other bank just has a normal exhaust manifold not going through the exhaust turbine.
The turbo compressor supplies boost to all cylinders.
This works quite well where only a low boost pressure is required, and saves space and cost.
Cheers, Tony
What needs to be done to an H22a internally to make it boost safely? preludeguy017 JDM Motor & Parts info/chat 1 06-02-2010 01:28 AM
turbocharger or supercharger J_U_ice Forced Induction 3 05-18-2009 09:07 PM
What Type Of Systems You Guys Rollin' With DR-VTEC Integra 15 08-17-2004 11:49 AM
What cat back system should I get? drdoom7373 Camaro Discussions 5 04-13-2004 11:11 PM
Does Any One Know What Big Brake System Is Made For The P11?? G20TurboVisionCrew Suspension 21 03-10-2002 12:15 PM
