Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 07-04-2003, 03:22 PM
S/C Prerunner S/C Prerunner is offline
Transmission Bump/Thump??? At Stops
I've got a 2000 Automatic V6 Prerunner & the thing has started bumping when I come to a stop, or start to take off. It's like the drivetrain is binding up during the stop & then unloading with a big thump? The dealership ofcourse says, "Nothing's wrong". Transmission runs/shifts smooth. I've looked at the Trainy mounts & u-joints, but I can't see anything wrong. I saw an old post, but no one replied. Anyone have a clue? Thanks!
Sorry for the long-winded post...
If I'm not haulin' ass in my S/C Tacoma, I'm Monster Truckin' stuff with my Jeep!
Old 10-18-2003, 02:58 AM
mpmckinley mpmckinley is offline
I noticed the same exact problem with my 02 ex cab. I am also not sure what exactly the deal is because actual shifting is still smooth. Can anyone help?
Old 10-18-2003, 09:54 AM
'03DC3.4TRD4X4 '03DC3.4TRD4X4 is offline
a dealer fix
I have heard that this is a problem with axle wrap. Some dealers have fixed this by disassembling and lubricating the drive shaft. Obviously this will reoccur so keeping the slip yoke lubed will help. An add-a-leaf should stop the wrap. This is just one of the downsides to a cushy ride.
Old 10-20-2003, 08:37 AM
Re: a dealer fix
You're right. I took mine back into the dealer & they lubed up my driveshaft. Then I installed an add-a-leaf to the rear & some short coil spacers to the front. My truck is about 2.5 inches taller, but no longer has the "bump". The add-a-leafs are a bit stiff, but cornering is significantly more stable. Plus my new 32"x11.50" tires look really good with the lift.
Old 10-20-2003, 02:17 PM
How much would I be looking to spend for that set up?
Old 10-20-2003, 02:45 PM
Re: Transmission Bump/Thump??? At Stops
I spent about $45 for the rear Add-a-leaf Kit off Ebay and $60 for the two rear Pro-Comp shocks from 4-Wheel Parts Wholesalers. I got the front Daystar Polyeurothane coil spacers from a buddy, but a number of companies carry these. (Surf the internet.) My spacers were for a 2.5" Tacome lift. The rear shocks were also for a 2.5"-3" Tacoma lift. The Add-a-leafs weren't specific on the actual lift, but I gained a little under 2.5" in the front, and a little over 3" in the rear. My truck now sits perfectly level and the 32's fit nicely.
Old 11-08-2003, 03:55 PM
Dreamer_ Dreamer_ is offline
Angry Re: Transmission Bump/Thump??? At Stops
My 02 Tacoma ex cab is in the shop right now getting a new engine (@24k) due to valve failure.(so they've told me)-First diagnosis was "scorched rings"
I also get that "Thump" in the trans. and I told them check that out too. I don't need any more surprises before the warranty runs out.
I'll let ya know what I find out.
Old 11-26-2003, 04:05 PM
Dogfly001 Dogfly001 is offline
I had the same exact problem, its a lack of lube in the driveshaft
Old 10-09-2004, 07:08 PM
wiz706 wiz706 is offline
i am having the same prob here
i wound a link that might help all of up
with the taco bump...
http://www.thesqueakywheel.com/compl...plaint5483.cfm
daniel brown
Old 11-15-2004, 12:46 AM
cluster1ne2112 cluster1ne2112 is offline
What is clunking is the rear slip joint... for some reason Toyota leaves them close to bone dry, and no one ever thinks to grease it. I had to put about 15 pumps into mine until it was actually full. I had that same problem on my 99 TRD 4x4, but after greasing that joint, its completely gone.
Old 11-15-2004, 05:04 AM
wrigley123 wrigley123 is offline
Is your Prerunner a 4x4?
MIke
Old 11-15-2004, 08:40 AM
Prerunners are only two wheel drive. They are identical to the 4x4 truck minus the t-case & live front axle.
Old 11-15-2004, 07:52 PM
Re: Re: Transmission Bump/Thump??? At Stops
i am still having the same prob with my 1998 taco extra cab..
dealer said its normal but not like this... going to try add a leafs to see if its the springs. i called a toyota parts department and the orignal springs(3 leaves) are no longer avail only the new(4 leaves)
sounds like their trying to cover somthing up..
daniel
middletown ny
check out this link again the more the better
thank you
Old 11-16-2004, 12:50 AM
lifetrddeath lifetrddeath is offline
Send a message via AIM to lifetrddeath Send a message via Yahoo to lifetrddeath
yes this is the rear slip joint and the problem is called axle-wrap. this has to be one of the most common problems with tacos. i've heard untreated, down the line it could lead to breaking the driveshaft. anyhow, yes, lubing the hell out of it helps, but doesnt fix the problem, though it may seem to for awhile. apparently adding eaither new leafs or doing a AAL can dramitcally help the situation or even using traction bars. the thing with the leafs, going from 3 to 4, is apparently there has been a rather large complaint about the 3 leaf system sorta giving out, weakening a whole hell of alot. So im guessing toyota is doing the 4 leaf thing to help counteract the situation. I'm personally going to try the AAL and see how things work out with my axle wrap problem.
Old 11-22-2004, 05:00 AM
My 2003 Mini 4cyl 42000 miles is currently at the dealership having the rear differential replaced. The "CLUNK" has been noticeable for about a month. There were no signs of anything wrong with the truck other than the "CLUNK". I only heard the noise after the truck was warmed up. The dealership did not hesitate to tell me that the rear differential was bad and needs to be replaced.
Mike
94 Caravan 4-speed transmission bump when it rains vgb14 Caravan | Voyager 1 09-11-2009 12:19 PM
1997 Transmission Bump GTS767 Camry/Camry Hybrid/Vista 5 08-23-2007 03:36 PM
Rear end bump after stopping striker6 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 10-12-2006 07:26 PM
2001 tacoma transmission bumping. Lurkin42 Tacoma 7 12-25-2004 07:11 PM
2003 Gr Cherokee transmission slipping in stop and go traffic? xtroll Grand Cherokee | Grand Cherokee SRT8 12 10-30-2004 01:14 PM
