Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-13-2007, 03:28 PM
GTS767 GTS767 is offline
1997 Transmission Bump
Its is a 1997 camry, 4 cyc with 150,000 miles. Lately when I shift from park to drive, here is a delay in engagement of the tranmission into gear. It typically takes a slight step on the gas, and then it kicks into gear and runs fine after that. This happens occasionally, and not all the time.
I know I should not have the transmission flushed with such high miles, but I have been keeping the transmission oil clean, but purging from the oil pan every so often and adding the difference. I have not had the drive axle oil replaced for a long time.
Could it be the transmission, or the filter screen, or a vacuum advanced leak.
Can you PLs advise
Thanks
Old 08-13-2007, 03:51 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 1997 Transmission Bump
If the fluid level has been good I would start with dropping the pan and inspecting/changing the filter.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-13-2007, 06:43 PM
davemac2 davemac2 is offline
AF - Advisor
Do as RIP says initially, but a delayed egagement into reverse is usually a sign of low trans pressure. Reverse gear engagement demands the highest pressure in a trans. You may have a leaky valve body or internal gasket in the trans causing this. The pressure can be checked fairly easily. You could specifically ask for that check at a trans shop to see. Has the trans ever had any work done on it?
dave mc
Old 08-13-2007, 08:13 PM
The transmission never had any work since new. The bump occurs when I go from Park to Drive, only. It does not do it in reverse.
I will pull down the oil pan and check for filter this week. If still no good I will take it to trans shop for inspection as recomended above.
Thank you for taking the time to respond quickly, and I will do likewise when T/S is complete with findings.
Old 08-21-2007, 04:01 PM
I have changed the filter screen and trans oil in pan. There has been no further reports of trans bump so far.
Old 08-23-2007, 03:36 PM
xfeejayx's Avatar
xfeejayx xfeejayx is offline
thanks for the update!! I have the same issue, will do the same.
