Old 07-04-2003, 01:58 PM
ddanweh ddanweh is offline
1990 dodge caravan -help
new to us van. won't start. looking for the fuel pump - where is it???
any other suggestions...
thanks
dw
Old 07-23-2003, 09:49 PM
williesworld williesworld is offline
gaaaaasssss taaaaannnnkkkkk!
BEER~Answer to most questions.
MORE BEER~Better answers!
Old 07-24-2003, 11:48 AM
DWJ DWJ is offline
When you turn the key on, can you hear any sound from the gas tank area? It will be low and only last a few seconds. If you do, that's your fuel pump kicking in and pressurizing. Then it stops. If nothing happens, check for a blown fuse for the pump.
Now ,if the pump kicks in and the motor turns over, do you have spark?
Old 07-24-2003, 05:56 PM
Thanks, found the pump.
I'll try listening for the sound and go from there.
We can actually get it to run - for about 30 seconds.....
thanks
dw
Old 11-13-2003, 07:12 PM
yale329 yale329 is offline
Re: 1990 dodge caravan -help
You did everythig right, but, just because you can hear it does not mean it's workingt properly. Get your fuel pump pressure tested before your van stops where you least want it to. It's quite a cheap test. Also possible your due for a fuel filter change..
Old 12-02-2003, 07:53 PM
aleksandr aleksandr is offline
Question check for a blown fuse for the pump
Where's this fuse,fuse block havn't one?
1990 Dodge Caravan radiator fan thermaldisc Caravan | Voyager 2 01-31-2005 08:29 PM
1990 Dodge Caravan anti-sway bar. Lee W Caravan | Voyager 2 06-26-2004 09:56 AM
1990 dodge caravan front brake rotor removal jimdmartin Caravan | Voyager 1 04-28-2004 06:16 PM
1990 Dodge Caravan possessed by devil! chrisdrone Caravan | Voyager 2 03-14-2004 05:39 PM
1990 Dodge Caravan 3.0 V6 Fuel pump not working photogoods Caravan | Voyager 1 12-16-2003 07:09 PM
