Old 07-03-2003, 11:32 AM
bhaktiveda bhaktiveda is offline
Question 91 Accord "Oil light" (RED) Flashing and "Check Engine" (YELLOW) on when slowing
Newbee, please help to understand, when I take a sharp turn my Oil Light(RED) comes on and keeps flashing till I turn the engine off, also my "Check Engine" light comes ON when I slow down my speed from 65-70M/hr to 40M/hr.
Car Profile:
1991 HONDA Accord EX
227000 Miles logged
4 Dr Sedan
Silver
HondaNirvana
Old 07-05-2003, 12:04 PM
Duatone Duatone is offline
3 words... change your oil!!
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 07-05-2003, 03:59 PM
lorunner lorunner is offline
yeah or at least put some in it .
Old 07-05-2003, 05:26 PM
BullShifter's Avatar
Sounds like your oil is dangerously LOW. For the check engine light, find out what code it is.
Oil light means NO oil pressure! or bad sending unit
Old 07-05-2003, 07:09 PM
Thanks you all..for your help, went directly to my Honda dealer and got a complete oil change. No more RED flashing light, I tried to get the Check engine codes...seems there are many of them should I remove all the code by unplugging the battries and then start freash?
Any suggestions.
Great works folks keep HONDAOING
HondaNirvana
Old 07-05-2003, 09:35 PM
Multiple codes in most cases means that the ECU is bad. 1st clear the codes by removing the main fuse in the underhood fuse box & re-check for codes
92 Accord hard to shift in and out of park rango25 Accord/TSX/Accord Hybrid 5 11-12-2009 04:57 PM
"Trac Off" and "Check Engine" light keeps coming on... LtCmdrFlygirl Cavalier Problem Diagnosis 2 11-02-2005 03:36 PM
"ETS Off" Light and "Check Engine" Light stay on! lordfritter Grand AM 12 04-18-2005 04:20 PM
motor vibration in drive and thumping in front when slowing down. ringlett1 SC/SL/SW 1 03-16-2005 10:46 PM
"check engine" dash indicator flashed on&off roan22 Escort 0 09-22-2004 10:00 PM
