Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-21-2016, 07:04 AM
Skruff Skruff is offline
87 Toyota 4runner cranks but no power to ignition
My Toyota 4-runner has a new starter, and has started since the starter was installed, but after I installed new tail lights, I turn the key and there is no power to the ignition, and the none of the dash lights go on EXCEPT the one which reads charge. I have checked all the relays and fuses, no problems there, and I have had the computer out and checked by a dealer, but still no power to the ignition...anyone else ever deal with this?
Old 09-21-2016, 09:52 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 87 Toyota 4runner cranks but no power to ignition
Did you check your battery? It might be almost or totally dead. Might be the fault of the alternator. Have them both checked.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-21-2016, 10:19 AM
Battery good, Alternator putting out 14. The idiot lights and the signals don't work, but the motor cranks over healthy. I'm thinking a fusible link, or fuse that I have missed. Checked the ones behind the kick-panel (driver's side) behind the glove box, and under the hood near the battery.
Is there a circuit breaker on the ignition wire leading from the Starter?
Old 09-21-2016, 02:28 PM
Brian R.'s Avatar
Resident Chemist
Replace the AM1 40A fuse under the hood if it exists. Might be your problem.
Also, replace the wire from the positive battery terminal to the fuse box. They have been known to corrode internally or create a bad connection to the point of causing electrical problems like you describe.
The Following User Says Thank You to Brian R. For This Useful Post:
Skruff (10-09-2016)
